I use the echo out quite a bit and sometimes i might have a track looped then activate the effect. What happens is that when the echo loop has reached the end of its set lenght, the songs starts playing again. I believe this happens sometimes, not all the time.
Is there any plugin guru out there that can take a look at this one and maybe correct this issue. While i think of it the beatgrid effect would sound great if it had an echo out on the last sound played. thanks
geposted Mon 15 Dec 08 @ 12:36 pm
What are you looking for?
Do you want a plugin which provides the echo loop and at the same time the sound goes lower till volume 0?
geposted Mon 15 Dec 08 @ 2:08 pm
wouldnt that be the LOOP OUT plugin??
geposted Tue 16 Dec 08 @ 8:16 pm
my echo sork like this when i finish using it and i put the volume down and i load another song and i activate the echo it just goes up the chart activating it imediatly
geposted Tue 23 Dec 08 @ 9:53 am
