Does anyone use the backspin plugin and able to activate it then have it automatically dis-engage after the track stops ?
If you set as Temporary on a shortcut key, after the effect executes completely, the effect (button) remains ON, even after letting go of the shortcut key. If you let go of the shortcut before the effect causes the deck to stop, then it reacts as expected (temporary).
geposted Sat 12 Feb 05 @ 3:09 pm
