I am using Mix Station SV 04 V2.06. I would like to add my DJ name to it somewhere. How is that possible?
Great skin by the way...
MS
MS
geposted Mon 14 Feb 05 @ 3:08 am
Edit the bmp image (in zip file) and add your name or logo...
geposted Mon 14 Feb 05 @ 3:11 am
I already done that and still nothing...
MS
MS
geposted Mon 14 Feb 05 @ 3:17 am
it might be that you've added it UNDER another part of an overlaid image..
therfore the other image is simply sitting above your grpahic
double check where it is ;)
geposted Mon 14 Feb 05 @ 12:38 pm
Thanks!
MS
MS
geposted Mon 14 Feb 05 @ 1:15 pm
I forgot all about changing the skin until today. I still to change the bitmap image in the zip file. But when I open VDJ and activate the skin, nothing has changed. I am trying to add my DJ name to the skin and make some minor cosmetic changes. If anyone has a clue then let me know.
MS
MS
geposted Sun 15 May 05 @ 8:33 pm
Be REALLY sure the pic you changed is updated in the zip file...
geposted Sun 15 May 05 @ 9:48 pm
I changed the skin in the zip file but everytime I save it, it shows that it is being saved. But once I open the skin up nothing has changed.
MS
MS
geposted Sun 15 May 05 @ 10:29 pm
"it" (your zip software) probably saves the file in a temporary location. You have not to only save the bmp, but to re-do the zip too I apologize.
What I suggest to you : extract the bmp file to the location you're sure to find out, and then modify here the file. When the file is ready, add it again to the zip archive. It should work better...
FRUiT94
FRUiT94
geposted Sun 15 May 05 @ 10:35 pm
I just did it and when I opened up VDJ it's default skin came up. When I try to activate the skin an error message says invalid skin file error in line 0 of the xml.
MS
MS
geposted Sun 15 May 05 @ 11:04 pm
Did you change a part of the xml too?
Have you included the xml file? If you created a new archive
This error mostly happens when a sign " is missing somewhere in the xml...
geposted Sun 15 May 05 @ 11:10 pm
once you change the bmp, you must ad the new saved image to your zip archive. Since it still must have the exact name, you should be prompted to overwrite the existing file.
geposted Mon 16 May 05 @ 12:08 am
Give me the skin name and the logo you want... I can make it to you and send me your email too to send the new zip file again there... --@--.-- send me there
Moderated by Lady Cameron
Sorry Dj_Marie no email address is allowed from a demo user
geposted Wed 18 May 05 @ 9:48 am
please unzip the skin in some directory (both xml and bmp file),
edit the bmp file, save it and then pack the two files in the directory to a zipfile.
This worked for me
This worked for me
geposted Wed 18 May 05 @ 1:57 pm
when you save the bmp, look that you save it as an bmp and not a jpeg.
i think that the skin wasn't working because there was no bmp in the zipfile anymore..
good luck..
good luck..
geposted Wed 18 May 05 @ 2:25 pm
Thank you everyone, I will look into it.
MS
MS
geposted Wed 18 May 05 @ 5:04 pm
gracias por ayudarme a conseguir nuevos accesorios para virtual d.j
geposted Thu 19 May 05 @ 9:31 pm
Please post in english here because if we cannot understand your request we wouldn't be able to help you.
geposted Fri 20 May 05 @ 8:48 am
