Can someone create a simple timer plugin, (or if there is one point me in the right direction)
I would like a timer that can started manually or automatically,when VirtualDJ is launched. Also would it be possible to show your hour's played in the that night (or your last gig) and a total hour's played with VirtualDJ. There is a timer on the skin I use, but it resets itself after 60 mins.
It will interest me in the length of time I've played for, and total time I played for without having any issues or problems (it will be interesting to see how relieble VirtualDJ actually is aswell)
geposted Mon 29 Dec 08 @ 6:33 am
You would have to remember to activate the plugin manually (or use the registry which I believe has an option that can be used to auto-activate plugins?)... is that a problem? Also I'm not aware of a way of displaying a plugin output on the skin, so would have to be dispalyed in the plugin window only?
geposted Mon 29 Dec 08 @ 7:28 am
No mate, I don't mine, I just find, it will be interesting ( I know, how sad, lol)
geposted Mon 29 Dec 08 @ 7:32 am
Should be simple, I'll have a look later on today if you want :)
geposted Mon 29 Dec 08 @ 7:59 am
Cheers Scott
geposted Mon 29 Dec 08 @ 8:38 am
