Hello everyone,
I\'ve had the RMX for a bit now and have found that the crossfader in my unit does not always work properly. From time to time, when the crossfader is clearly all of the way to the left or right on the RMX, VDJ does not register it as being at the proper point (i.e. all of the way to the left/right). The result of one case where I attempted to put the crossfader all of the way to the right is as follows:
This happens on two computers, which leads me to believe that it is a problem with the RMX. Does anyone have any ideas?
geposted Mon 29 Dec 08 @ 4:40 pm
Hello chise1,
If it happens only
- with VirtualDJ 5,
- when you move very fast the crossfader,
- and if re-moving the fader immediately makes VirtualDJ actualize (reset properly) the position,
then I have also met this bug, and I have met this bug only in VirtualDJ 5, not with any other DJ software, so I don't believe it is a hardware problem, I think it is a software issue.
If it happens only
- with VirtualDJ 5,
geposted Tue 30 Dec 08 @ 2:39 am
See: https://virtualdj.com/forums/92593/Hardware_Technical_Support/RMX_and_scratching_with_the_crossfader.html
The XML code has been removed from the post, not sure why :(
Using midi mode will make the fader shut off sound to the other side and the fader will keep up. I was unable to get the FFW and Rewind, EQ kill buttons to work.
geposted Tue 30 Dec 08 @ 9:25 am
