I'm having trouble with external mixer to work with virtual DJ. Can someone help me with different settings to make the external mixer work with virtual DJ. Thank you for all the help.
geposted Tue 30 Dec 08 @ 5:34 pm
Before we can help, can you give us some more information? Such as what mixer you are trying to hook up, what OS your using, are you using TCV's or TCCD's? What external soundcard you have?
Thanks
Syberman
Thanks
Syberman
geposted Tue 30 Dec 08 @ 7:34 pm
I'm using the Denon-Dn-HD2500 & the mix is the Denon DN-x500 & the soundcard is the Asio that is built in the Denon 2500
geposted Tue 30 Dec 08 @ 7:53 pm
You need a external sound card like a Maya 44 that has 4in/4out. It doesn't have to be a Maya 44, just a external sound card that has 4in/4out capabilities.
Syberman
Syberman
geposted Wed 31 Dec 08 @ 12:14 pm
The Denon HD2500 already has a built-in sound card which can be used with VirtualDJ, please see http://www.denondj.com/plugin.asp?prod=DN-HD2500 for the ASIO driver.
Also, please see answer to your other topic:
https://virtualdj.com/forums/102076/PC_Version_Technical_Support/Help_with_Virtual_DJ_Software___Denon-Dn-hd2500.html
geposted Wed 31 Dec 08 @ 3:39 pm
I have a MAYA44 Ex-Sound card can you help me with SETUP! THANK SO MUCH
geposted Wed 31 Dec 08 @ 6:19 pm
Connect a suitable cable to outputs 1&2 (Standard RCA phono cable for USB version) and connect it to channel 1 of your mixer. Connect a second cable between outputs 3&4 and channel 2 of your mixer.
Install the ASIO drivers for the sound card (If you are using the USB version, always make sure you use the same USB port on your computer.)
Choose the following settings in VirtualDJ:
Performances:
Latency: AUTO
Safe mode: NOT ticked
Overclock: NOT ticked
Sound Setup:
Inputs: NONE
Outputs: External Mixer
Sound card(s): ASIO driver
ASIO driver: Maya44 ASIO driver
DON'T tick ultra latency.
Click on the ASIO button and choose the following options in the Maya44's ASIO config tab:
ASIO resolution: 16 bit
System Performance: Highspeed
Restart VirtualDJ for the ASIO settings to take effect.
If you get sound break-up or stuttering, set the ASIO system performance in the Maya44 control panel to a lower speed, e.g: Rapid (You will need to restart VirtualDJ afterwards for the new setting to take effect.)
Performances:
Latency: AUTO
Sound Setup:
Inputs: NONE
geposted Thu 01 Jan 09 @ 1:22 pm
just download 30 day version,..ive put music files on and can play no problem,....but,....i just cannott find the button to mix both turntables so i can walk away and just let it play one song after another,....please help.......jon
geposted Thu 01 Jan 09 @ 1:25 pm
Please post a new topic with your question - Please don't hi-jack a thread that is not related to your question in any way.
geposted Thu 01 Jan 09 @ 1:41 pm
hey umm i jus bought anotha mixer it is the vestax PVC-175 its not a usb mixer am i stll able to use this mixer with the dj console mk2 if so can u step me through the set ups? thanx i would really appreciate it.
geposted Thu 01 Jan 09 @ 10:49 pm
