Forum: Wishes and new features
Topic: Cue--->Stutter
dydy1PRO InfinityMember since 2006
Is it possible to add scratch with Virtual DJ? I mean, going from stutter cue to scratch, stutter cue -> scratch -> stutter cue -> scratch, and so on.
To simplify all this, my question is: Can you make Virtual DJ return to the cue point by itself, right after you release the platter after a scratch?
Is it possible to create a short cut that can do that?
geposted Thu 01 Jan 09 @ 2:23 am
DJAuzPRO InfinityMember since 2008
If the track is already at the cuepoint, if you press and hold cue it will play the track, as soon as you let go of the cue point it will jump back to the cue point?
If you are using a midi interface you should be able to scratch the track whilst holding the cue button?
Is this what you're describing, or am I way off the page?
Good Luck =Þ
geposted Sun 04 Jan 09 @ 11:15 pm
Do you mean like the cdj's have it.
You set a cue point then you scratch and if you put your hand away from the jogwheels it's jumping back to th cue point...
Is that what you mean?
With midi I think that will be possible but with tc- I don't know
geposted Sun 11 Jan 09 @ 12:55 pm
That Is what I mean
geposted Sat 24 Jan 09 @ 4:31 am
