I use turntables, and virtual dj vinyls, i can play anything i want but when i stop the music, an annoying noise comes from the speakers (like buzzing and clicking) , but when i play again the noise is gone, or if i turn the volume down. why? how can i stop that?
geposted Thu 01 Jan 09 @ 1:51 pm
are your turntables earthed to your mixer, or could be your gain is to high up.
geposted Thu 01 Jan 09 @ 2:14 pm
I dont think they are earthed, how can i do that?
geposted Thu 01 Jan 09 @ 2:43 pm
usually there is a single trailing wire at the back of your decks, or there could be like a "lug" there instead and a similar one on the back of your mixer, if there is no trailing wire simply get some light single core wire and make connections between these two points, but either way you must somehow make a firm connection between decks and mixer bodies.
hopefully this will cure your problem if not you will then more likely need a ground loop isolater, don,t worry they are not expensive.
geposted Fri 02 Jan 09 @ 6:18 am
you could also check this thread out also, may help you...
https://virtualdj.com/forums/77890/General_Discussion/Buzzing_And_Humming_(Mods__please_make_sticky).html?page=1
geposted Fri 02 Jan 09 @ 6:20 am
I had the same problem, caused by floating earth.
Easiest thing to do is jump on ebay and look for a 'ground loop isolator', their are many different types depending on your configuration!
Something like this should do the trick, and cost less than US$15;
http://cgi.ebay.com.au/NEW-GROUND-LOOP-ISOLATOR-NOISE-SUPPRESSOR-FILTER-KILLER_W0QQitemZ270321761356QQihZ017QQcategoryZ102568QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Good Luck!
Good Luck!
geposted Fri 02 Jan 09 @ 11:21 pm
ok, i dont have problem with both TTs, only one of them, and i noticed that when i stop the turntable, virtual dj does not stop it, but on the other deck, which work perfectly fine, vdj stops/pauses the track as soon as i stop the TT. why? how can i fix it?
geposted Sun 11 Jan 09 @ 10:57 am
