I tried to config my vinyls on virtual vinyl but it says "Error in ASIO Drive". What should I do?
geposted Sun 04 Jan 09 @ 11:16 am
You have to complete the set-up / connection of your VV box and your turntable or cd player as per in the MANUAL then click Input TIMECODE.
geposted Mon 05 Jan 09 @ 3:53 am
Ok now it has the wave but no quality I need urgent help. See pic below
geposted Mon 05 Jan 09 @ 2:21 pm
<a href="http://tinypic.com" target="_blank"><img src="http://i40.tinypic.com/5oaubl.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
You should download the latest version from the download center. The screen shots you are showing are from an old version.
https://virtualdj.com/download/updates.html
geposted Mon 05 Jan 09 @ 2:32 pm
it shouldnt really matter though. I tried it but it still wasn't working so I uninstalled it and reinustalled my disc.
geposted Mon 05 Jan 09 @ 3:03 pm
Have you tried Auto-Config? I think the TC Up may be too high.
geposted Mon 05 Jan 09 @ 4:12 pm
Switch your VV box to line (from phono to lline) then click Software RIAA Preamp, those, try click invert phase also then auticonfig. If you can get a signal maybe try to adjust the TC up or down to fine tune it and to have a stable 100% signal.
geposted Tue 06 Jan 09 @ 2:02 am
thank you my timecodes now work, but I cannot hear anything
geposted Tue 06 Jan 09 @ 12:03 pm
well they control the song but their is no song playing (muffled and static and whatever else) and the quality varies and when I press auto-config the quality goes to 0%
geposted Tue 06 Jan 09 @ 12:15 pm
Please check on the diagram below if you have the properly set your machine up:
You have to fine adjust the TC up or down to get a stable signal. Small increment or decrement with the slides can have a big effect with the signal quality.
BTW I'm using the VDJ Timecode V4, try it also.
Lastly check your needle...
geposted Wed 07 Jan 09 @ 3:57 am
I dont remember which version but there was a funky bug in the auto config. As far as I can see every looks good, I would install the lastest version and make sure you have the soundcard plugged in and active before running virtual vinyl.
geposted Wed 07 Jan 09 @ 8:54 am
Well I was told to try it using a TimeCode CD, Same the sound is muffled but there is nothing wrong with the speakers so a diagnosis please!!
geposted Wed 07 Jan 09 @ 11:50 am
