Forum: VirtualDJ Skins
Topic: VDJ symbol flashing on cdj700 skins ???
Hi all,
I just DLed the latest CDJ 700 skins... and the VDJ logo (top left corner) has now got a bigger (standard)VDJ logo over the top of the original blue one ! and it flashes..
Just wondering if anyone else has/had this problem....im going to have a FIT LOL
I dont mind it being there but is there a way to STOP it from flashing ??? (or remove it ..not fussed)
I found a thread a while back on this same thing but cant dig it up :-(
any help would b great
cheers
CB
geposted Wed 07 Jan 09 @ 8:22 pm
From now on, if a skin doesn't have the logo element in the XML, a big VirtualDJ logo will appear at the top left and it flashes if the rhythm is under it.
To prevent this, add this code to the XML file:
<logo>
<size width="0" height="17"/>
<pos x="0" y="0"/>
</logo>
Make sure there is no other element (button/visual/textzone...) at the top right corner (position X=0 Y=0).
top left :)
(not trying to be picky though)
yeah lol, i always get mixed up when talking about the left. But i know right is at the right :)
Thanks jeremk
Im not sure were to put it tho .. I tried droping it in at the top of the xml (on the left lol) ..but keep getting msg when trying to load it in VDJ
(invalid skin file error line 0 in the xml)
if you could show me just the part were it should go ...or what i may be doing wrong... would be great :-)
thanks again for your help peeps
CB
be careful on the placement of the logo it cannot overlap or touch any other element, it needs it own space. So you could have either had an error in the line of code or the logo was touching something else.
here is how i did it ...its only the first page so u can see ...but didnt work for me :-(
Quote :
<Skin name="Pioneer CDJ 700S" version="1.0" width="1024" height="768">
<copyright>- (c)2002 - Fabio Zanardini zanard1@virgilio.it -</copyright>
<logo>
<size width="" height="17">
<pos x="0" y="0">
</logo>
<browser>
<size width="988" height="265"/>
<pos x="00" y="503"/>
<text font="comic ms" size="17" weight="bold" color="#09D4F8"/>
<options font="comic ms" size="17" color="#09D4F8" over="#0000FF"/>
<widgets font="Virtual DJ" size="10" color="#99DDFF"
facecolor="transparent"
lightcolor="#0000FF"
shadowcolor="#0000FF"
darkshadowcolor="transparent"
highlightcolor="transparent"
trackcolor1="transparent"
trackcolor2="transparent"/>
</browser>
You have to write width="0"
Check the version on the first line. It has to be at least version "5.0" or "500" (the first number has to be a number 5)
AHH !!! it had an 0 missing ..i just cut it from jeremk's post above ..i did see the "" and wondered if somthing was missing LOL ill give it ago now....
Cheers
CB
(EDIT)
Ok i put the missing 0 in but still get the same msg... I really dont know what im doing :-(
As for the version ..do u mean for the skin (were it says version in code at top ??) .. Do i need to change it or is the skin wrong version ?? ..im a bit lost
Sorry to B a pain thanks heaps
CB
I discovered what was going on ! ...there was A / missing from end of "pos" line ...
So i got it to work YAY... BUT... the logo is still there... just smaller and "STILL" flashing
Also now the setup menu or record menu will not apear when I click on it .........DOH ??
I think I might just put some DUCT TAPE on screen to cover it up LMAO
what am i doing wrong ?
CB
Try this code:
<logo>
<pos x="0" y="0"/>
</logo>
If it doesn't work, this one:
<logo>
<size width="68" height="17"/>
<pos x="0" y="0"/>
</logo>
I'm sorry the code I initially posted was wrong.
Thanks heaps JeremK, NP
Yep the second one works :-) (made logo smaller)... and the setup menu and record menu work also (not with the first code tho !)
Now I dont want to sound fussy but is there a way to stop it from flashing ??? or get rid of it all together...the CDJ 700 skins do have the VDJ logo already onit so it dosent really need the 2...
Thank you again for all the help for such a little thing (i just find it rather distracting the little flashing thing in corner of screen grrrrrr)
CB
Ok I sorted out my prob :-) ....went and did some reading on making skins HE HE ...understanding whats going on now ...im moving it all over the screen (and out off CBG so it doesnt flash anymore !!!! YAY)
Thanks again for help peeps
CB
