I had the time to try resizing a skin today but in doing so I think i moved the skins folder to my desktop and when I tried to open my VDJ it gave an error - "invalid skin file" Now I can't use my VDJ. Can somebody out there offer me some help? In the meantime I'm trying to re-load the skins folder to where ever I oved it from and hopefully I can use my VDJ again.
Thanks,
Luis
Thanks,
Luis
geposted Thu 08 Jan 09 @ 1:00 pm
the folder you probably moved should be located within My Documents \ Virtual DJ
geposted Thu 08 Jan 09 @ 1:57 pm
Erxon,
Thank You Very Much! I got to use my VDJ again!!!
Luis
Luis
geposted Thu 08 Jan 09 @ 3:43 pm
CAN ANYONE ONE HELP
I tried to put a new skin on but when trying to do this i deleated my old skin in stead, triend to refresh it but cant find it now it wont even open at all thank
geposted Fri 16 Jan 09 @ 7:30 pm
You can download the RMX skin here:
http://www.virtualdj.com/addons/4554/Hercules_RMX___Steel.html
You could also install the software again to solve the problem.
geposted Sat 17 Jan 09 @ 3:41 am
