SBDJ wrote :
Did you enable TS mode on the two channels in the MIDI mixer setup screen?
Swizzle1001 wrote :
Xenon I am having a bit of problem.. I was able to get the TimeCode up and running but I am hearing a beeping sound come through my speakers.. what am I doing wrong?
No i didn't do that SBDJ...
geposted Thu 15 Jan 09 @ 6:33 am
You can access it in the MIDI settings (Hold MIDI and settings) "mixer" section from memory...
geposted Thu 15 Jan 09 @ 11:23 am
ok.. i am doing this rite now...
geposted Thu 15 Jan 09 @ 11:40 am
Once it's enabled, you should have a blue light on that channel, I can't remember if it flashes or not for TS mode. That channel then takes the phono signal, sends it to VDJ, and VDJ sends an audio signal back that comes out of the same channel.
You can then save this overlay with that change, and when you select that MIDI overlay in the future the mixer will automatically reconfigure.
geposted Thu 15 Jan 09 @ 11:42 am
ok i did that.. the blue light flashes.. when i enabled the TS mode for Input 1( should this be the channel that I am sending the Time Code signal from the Player that I am using)
geposted Thu 15 Jan 09 @ 12:04 pm
Ok.. SBDJ.. this is the problem I am now having... Channels 1&2 r my main output channels.. Channel 3&4 are to be my headphones.. but for some reason I can hear them through my main speakes... the beeping bit is solved. thanks for that bit of info earlier..
geposted Thu 15 Jan 09 @ 2:11 pm
I'm not sure I understand what you mean by headphone channels? The Ecler provides it's own PFL setup?
geposted Thu 15 Jan 09 @ 5:09 pm
yea.. thats what i am saying too.. but when i go to the config page in VDJ.. my options are either Master: Channel 1&2/Headphone: Channel 3&4 or Master: Channel 3&4/Headphone: Channel 1&2
My main outputs is Channel 1&2 with my Headphone Channel 3&4... but for some reason my headphones are coming through the main... this is stress.. any suggestion...
geposted Thu 15 Jan 09 @ 5:26 pm
Use the "External Mixer" option, not the "Headphones" option. Then you assign each deck to a channel - so Left Deck 1/2, Right deck 3/4. The Ecler will then function as though you just had the two decks hooked directly to it, using the built in PFL functions :)
I in fact use "3 Lines Mixer" so the sampler is assigned to 5/6 :)
geposted Thu 15 Jan 09 @ 5:31 pm
Thank You SBDJ.... I never thought about that option.. Thank you man... I really appreciate it man...
geposted Thu 15 Jan 09 @ 5:44 pm
All sorted? :)
Hey SBDJ.. Have u any ideas.. how to get the high, mid and bass knobs to work.. only the master gain for each channel works...
geposted Thu 15 Jan 09 @ 5:53 pm
SBDJ wrote :
All sorted? :)
Yea.. SBDJ.. Its sorted to a point that i won't end up in a mental institution.. thanks for the patience man... i really appreciate it.. lol :-o)
geposted Thu 15 Jan 09 @ 6:02 pm
They should just work as per normal on the channel?
geposted Thu 15 Jan 09 @ 6:05 pm
they aren't working when I am playing VDJ through the mixer.. but If I should connect my CD players directly to mixer I am able to manipulate these knobs as i like..
geposted Thu 15 Jan 09 @ 6:22 pm
Hey SBDJ.. I restored the Mixer back to Factory settings and everything is working like it should except for the PFL & MIX... for some reason i am unable to hear anything from the opposite deck which is not being played through the main output (through my headphone)
geposted Fri 16 Jan 09 @ 7:24 am
Here is the new problem.. whenever I am playing from my DnHs5500 the PFL function works flawlessly.. however whenever i decide to play through VDJ, I am unable to hear the song that i wanna mix with one that coming through the main output (not even channel lights is on in the mixer, it only comes on when i decide to move the fader to enable it to come through the main)... any ideas why this is acting this way...
geposted Fri 16 Jan 09 @ 8:20 am
Let me try to recap a little...
1) When playing on your Denons, its timecode right, that is used to control VDJ?
2) What do you mean by playing in VDJ then? Playing without using the Denon as timecode controller?
And as for the knobs and all to work, you have to enable midi, and map them up in VDJ, or use a premade mapper... (if one is made)
geposted Fri 16 Jan 09 @ 8:28 am
I'll do a guide for you when I get home from hospital tonight :)
You don't need to map the controls or anything, the audio section should still function perfectly :)
geposted Fri 16 Jan 09 @ 8:54 am
appreciate it man.. thank you... sigh of relief...
geposted Fri 16 Jan 09 @ 9:04 am
