Just downloaded version 2.06 and noticed a file was downloaded with scratch effects(dll) but when I try to use them like other effects nothing happens. It says that the effect window I try to load them into is empty. What am I doing wrong? What are these files and how do I use them?
Thanks
Thanks
geposted Sat 19 Feb 05 @ 3:01 am
Scratch effect are special effect
put them into the main directory "virtualdj"
then go into the settings, in the plugins section and select your auto scratch plugins here
geposted Sat 19 Feb 05 @ 3:03 am
I did just like djcel said and copied them to the main directory and added them in the plug in page of the settings but now how do I get them to work? LOL this is kickin my ass.
geposted Sat 19 Feb 05 @ 3:08 am
use a skin with the button "scratch" (or "s" sometimes) or create a key shortcut "auto_scratch" to activate/desactivate the plugin
geposted Sat 19 Feb 05 @ 3:39 am
OMG, LOL thank you so much, I was looking for some kind of button that would make it work guess it would help if I had a skin that was designed for 1.06. Thanks again.
geposted Sat 19 Feb 05 @ 3:50 am
Have a look there: https://virtualdj.com/forum/display.html?topic=7230
geposted Sat 19 Feb 05 @ 4:42 pm
