Hi, first of all its not my speakers
there working fine cause when I play songs outside of virtual dj, I get the same level of volume from either speaker,
but just when I started playing a song on both turntables in virtual dj, the turntable to the right is alot louder then the turntable on my left when I play songs simultaneously.
My sound setup is:
Input: None
Outputs: single output
soundcard: simple
soundcard: realtek hd audio
what am I doing wrong? I just downloaded this trial cause I want to start getting into dj but is this a bug or what?
cheers
My sound setup is:
Input: None
soundcard: simple
cheers
geposted Wed 21 Jan 09 @ 4:31 am
just a quick update on it,
when I just play a song on the left turntable , its very low even though its set to the normal DB
I dont know if I might of screwed around with the settings in vdj ,
but is there a way to fix this?
cheers
edit*
I just clicked on reset to factory settings
and it fixed it
cheers guys :P
cheers
edit*
and it fixed it
cheers guys :P
geposted Wed 21 Jan 09 @ 5:04 am
it was in your sound setup config window. you had it set to headphones and when you where playing it one was louder because one was outputting your headphones.
geposted Wed 21 Jan 09 @ 9:04 am
