Forum: Old versions
Topic: VCI-300 NOTICE TO MR. JPBOGGIS
Dear Friend JPBOGGIS.
I have an offer. Starting from a price
of 50 euro ,do you accept to help me
in making the .DLL file for vci-300 controller?
Please inform me if you are interested...
Kind Regards
Jim
geposted Thu 22 Jan 09 @ 12:16 pm
JPBoggis or any one the forum would be glad to help you, and I'm sure for free. But you must first show your commiment to the software. Meaning become a registered owner of VDJ
I understand.
I am a very close relative of user Giannoulopoulos
who has registered the software.
He asked for help... but nothing happened ,thats why
i am asking this specific help from user jpboggis who
i guess has more knoledge then me :)
Thanks again.
You cannot make a proper (dll) VCI-300 mapper until native support is in place within VirtualDJ. Your close relative was offered assistance, to say he got none is a complete lie.
Regards,
Scott
Unfortunately, it's not possible to make a .DLL until native support for the controller is implemented.
In the mean time, I could assist with correctly mapping input-only General MIDI mapping if I had a VCI-300 to play with, but I do not have one.
The pitch issue I have seen users mentioned on the forums could be bad MIDI implementation, such as the LSB and MSB of 14-bit pitch being swapped (I have come across this before on another controller with 14-bit pitch, which the manufacturer fixed with a firmware update.)
Regards,
Scott
I PMed you as well Giannoulopoulos..........
Regards,
Scott
Yes ok he got assistance but with no results . Lets hope one day they'll have native support.
Regards
Jimmy
Regards,
Scott
Because i am not a licenced user i cannot see PMs :)
Thanks anyways...
Regards
Jim
_______________
Mr JPboggis, you mean that the controller must be also listed inside
the list along with the other controllers there ,in order to make a .DLL
file and put it in "my documents\virtualdj\plugins\controldevice" ???
About this controller, the dealer said it has the latest firmware... but
in Vestax also i havent seen any newer firmware update ... i even dont
know if this controller takes updates ... This 14-bit issue is a pain in the ass :)
Thank you so much - also my congrats about the latest .DLL for denon hc-4500
( i happen to own one denon and it works fantastic - excellent )
Regards
Jim
Most controllers can be firmware updated to fix bugs or add new features.
If you are using the VCI-300 with a MIDI translator tool, it could be this that's at fault - I.e: The developer of the tool used the LSB instead of MSB.
To determine whether the controller itself has a faulty 14-bit implementation, please do the following:
  • Disable any MIDI translator tool you may be running.
  • Download and install MIDI OX (A MIDI monitoring tool): http://www.midiox.com/
  • Run it and then move the pitch slider on the VCI-300 in one direction (Up or down appropriately, depending on where it currently is.) Make sure you only move it in one direction, otherwise the output generated will be confusing.
  • Copy and paste the values here (20-30 lines should be sufficient.)
Glad you like it - Please consider purchasing the software - The mapper is only available to registered licensed users of VirtualDJ Professional: https://virtualdj.com/buy/
That is correct :)
Been busy as usual but here is the output, I ran the left Jog too in case you have some input about them as well
Starting at +6 to -6 with left Pitch control Slider
TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT
0005386F 5 2 B0 0D 7F 1 --- Control Change
0005386F 5 7 B0 0D 7F 1 --- Control Change
0005386F 5 2 B0 2D 00 1 --- Control Change
0005386F 5 7 B0 2D 00 1 --- Control Change
0005387A 5 2 B0 0D 7D 1 --- Control Change
0005387A 5 7 B0 0D 7D 1 --- Control Change
0005387A 5 2 B0 2D 00 1 --- Control Change
0005387A 5 7 B0 2D 00 1 --- Control Change
00053884 5 2 B0 0D 7B 1 --- Control Change
00053884 5 7 B0 0D 7B 1 --- Control Change
00053884 5 2 B0 2D 00 1 --- Control Change
00053884 5 7 B0 2D 00 1 --- Control Change
0005388E 5 2 B0 0D 79 1 --- Control Change
0005388E 5 7 B0 0D 79 1 --- Control Change
0005388E 5 2 B0 2D 60 1 --- Control Change
0005388E 5 7 B0 2D 60 1 --- Control Change
00053898 5 2 B0 0D 77 1 --- Control Change
00053898 5 7 B0 0D 77 1 --- Control Change
00053898 5 2 B0 2D 40 1 --- Control Change
00053898 5 7 B0 2D 40 1 --- Control Change
000538A2 5 2 B0 0D 76 1 --- Control Change
000538A2 5 7 B0 0D 76 1 --- Control Change
000538A2 5 2 B0 2D 20 1 --- Control Change
000538A2 5 7 B0 2D 20 1 --- Control Change
000538AC 5 2 B0 0D 75 1 --- Control Change
000538AC 5 7 B0 0D 75 1 --- Control Change
000538AC 5 2 B0 2D 00 1 --- Control Change
000538AC 5 7 B0 2D 00 1 --- Control Change
000538B6 5 2 B0 0D 73 1 --- Control Change
000538B6 5 7 B0 0D 73 1 --- Control Change
000538B6 5 2 B0 2D 60 1 --- Control Change
000538B6 5 7 B0 2D 60 1 --- Control Change
000538C0 5 2 B0 0D 72 1 --- Control Change
000538C0 5 7 B0 0D 72 1 --- Control Change
000538C0 5 2 B0 2D 20 1 --- Control Change
Starting at -6 to +6 with left slider
0006B697 5 2 B0 0D 01 1 --- Control Change
0006B697 5 7 B0 0D 01 1 --- Control Change
0006B697 5 2 B0 2D 20 1 --- Control Change
0006B697 5 7 B0 2D 20 1 --- Control Change
0006B6A2 5 2 B0 0D 02 1 --- Control Change
0006B6A2 5 7 B0 0D 02 1 --- Control Change
0006B6A2 5 2 B0 2D 40 1 --- Control Change
0006B6A2 5 7 B0 2D 40 1 --- Control Change
0006B6AC 5 2 B0 0D 05 1 --- Control Change
0006B6AC 5 7 B0 0D 05 1 --- Control Change
0006B6AC 5 2 B0 2D 20 1 --- Control Change
0006B6AC 5 7 B0 2D 20 1 --- Control Change
0006B6B6 5 2 B0 0D 06 1 --- Control Change
0006B6B6 5 7 B0 0D 06 1 --- Control Change
0006B6B6 5 2 B0 2D 00 1 --- Control Change
0006B6B6 5 7 B0 2D 00 1 --- Control Change
0006B6C0 5 2 B0 0D 08 1 --- Control Change
0006B6C0 5 7 B0 0D 08 1 --- Control Change
0006B6C0 5 2 B0 2D 00 1 --- Control Change
0006B6C0 5 7 B0 2D 00 1 --- Control Change
0006B6CA 5 2 B0 0D 0A 1 --- Control Change
0006B6CA 5 7 B0 0D 0A 1 --- Control Change
0006B6CA 5 2 B0 2D 00 1 --- Control Change
0006B6CA 5 7 B0 2D 00 1 --- Control Change
0006B6D4 5 2 B0 0D 0C 1 --- Control Change
0006B6D4 5 7 B0 0D 0C 1 --- Control Change
0006B6D4 5 2 B0 2D 00 1 --- Control Change
0006B6D4 5 7 B0 2D 00 1 --- Control Change
0006B6DE 5 2 B0 0D 0C 1 --- Control Change
0006B6DE 5 7 B0 0D 0C 1 --- Control Change
0006B6DE 5 2 B0 2D 60 1 --- Control Change
0006B6DE 5 7 B0 2D 60 1 --- Control Change
0006B6E8 5 2 B0 0D 0E 1 --- Control Change
0006B6E8 5 7 B0 0D 0E 1 --- Control Change
0006B6E8 5 2 B0 2D 40 1 --- Control Change
0006B6E8 5 7 B0 2D 40 1 --- Control Change
0006B6F2 5 2 B0 0D 10 1 --- Control Change
0006B6F2 5 7 B0 0D 10 1 --- Control Change
0006B6F2 5 2 B0 2D 00 1 --- Control Change
0006B6F2 5 7 B0 2D 00 1 --- Control Change
0006B6FC 5 2 B0 0D 12 1 --- Control Change
0006B6FC 5 7 B0 0D 12 1 --- Control Change
0006B6FC 5 2 B0 2D 00 1 --- Control Change
0006B6FC 5 7 B0 2D 00 1 --- Control Change
0006B706 5 2 B0 0D 12 1 --- Control Change
0006B706 5 7 B0 0D 12 1 --- Control Change
0006B706 5 2 B0 2D 60 1 --- Control Change
0006B706 5 7 B0 2D 60 1 --- Control Change
0006B710 5 2 B0 0D 14 1 --- Control Change
Left jog 12 o' clock going counter clockwise touching rim of platter
00074265 5 2 B0 1C 69 1 --- Control Change
00074265 5 7 B0 1C 69 1 --- Control Change
00074265 5 2 B0 3C 5F 1 --- Control Change
00074265 5 7 B0 3C 5F 1 --- Control Change
0007427E 5 2 B0 1C 69 1 --- Control Change
0007427E 5 7 B0 1C 69 1 --- Control Change
0007427E 5 2 B0 3C 5E 1 --- Control Change
0007427E 5 7 B0 3C 5E 1 --- Control Change
0007428E 5 2 B0 1C 69 1 --- Control Change
0007428E 5 7 B0 1C 69 1 --- Control Change
0007428E 5 2 B0 3C 5D 1 --- Control Change
0007428E 5 7 B0 3C 5D 1 --- Control Change
0007429F 5 2 B0 1C 69 1 --- Control Change
0007429F 5 7 B0 1C 69 1 --- Control Change
0007429F 5 2 B0 3C 5C 1 --- Control Change
0007429F 5 7 B0 3C 5C 1 --- Control Change
000742B2 5 2 B0 1C 69 1 --- Control Change
000742B2 5 7 B0 1C 69 1 --- Control Change
000742B2 5 2 B0 3C 5B 1 --- Control Change
000742B2 5 7 B0 3C 5B 1 --- Control Change
000742C3 5 2 B0 1C 69 1 --- Control Change
000742C3 5 7 B0 1C 69 1 --- Control Change
000742C3 5 2 B0 3C 5A 1 --- Control Change
000742C3 5 7 B0 3C 5A 1 --- Control Change
000742D3 5 2 B0 1C 69 1 --- Control Change
000742D3 5 7 B0 1C 69 1 --- Control Change
000742D3 5 2 B0 3C 59 1 --- Control Change
000742D3 5 7 B0 3C 59 1 --- Control Change
000742DF 5 2 B0 1C 69 1 --- Control Change
000742DF 5 7 B0 1C 69 1 --- Control Change
000742DF 5 2 B0 3C 58 1 --- Control Change
000742DF 5 7 B0 3C 58 1 --- Control Change
000742E9 5 2 B0 1C 69 1 --- Control Change
000742E9 5 7 B0 1C 69 1 --- Control Change
000742E9 5 2 B0 3C 57 1 --- Control Change
000742E9 5 7 B0 3C 57 1 --- Control Change
000742F3 5 2 B0 1C 69 1 --- Control Change
000742F3 5 7 B0 1C 69 1 --- Control Change
000742F3 5 2 B0 3C 56 1 --- Control Change
000742F3 5 7 B0 3C 56 1 --- Control Change
000742FE 5 2 B0 1C 69 1 --- Control Change
000742FE 5 7 B0 1C 69 1 --- Control Change
000742FE 5 2 B0 3C 55 1 --- Control Change
000742FE 5 7 B0 3C 55 1 --- Control Change
00074308 5 2 B0 1C 69 1 --- Control Change
00074308 5 7 B0 1C 69 1 --- Control Change
00074308 5 2 B0 3C 53 1 --- Control Change
00074308 5 7 B0 3C 53 1 --- Control Change
00074313 5 2 B0 1C 69 1 --- Control Change
00074313 5 7 B0 1C 69 1 --- Control Change
00074313 5 2 B0 3C 52 1 --- Control Change
00074313 5 7 B0 3C 52 1 --- Control Change
0007431D 5 2 B0 1C 69 1 --- Control Change
0007431D 5 7 B0 1C 69 1 --- Control Change
0007431D 5 2 B0 3C 50 1 --- Control Change
0007431D 5 7 B0 3C 50 1 --- Control Change
00074328 5 2 B0 1C 69 1 --- Control Change
left jog
12 o' clock going clockwise touching platter
0008E654 5 2 90 53 7F 1 B 5 Note On
0008E654 5 7 90 53 7F 1 B 5 Note On
0008E83C 5 2 B0 1C 68 1 --- Control Change
0008E83C 5 7 B0 1C 68 1 --- Control Change
0008E83C 5 2 B0 3C 68 1 --- Control Change
0008E83C 5 7 B0 3C 68 1 --- Control Change
0008E8FE 5 2 B0 1C 68 1 --- Control Change
0008E8FE 5 7 B0 1C 68 1 --- Control Change
0008E8FE 5 2 B0 3C 69 1 --- Control Change
0008E8FE 5 7 B0 3C 69 1 --- Control Change
0008E909 5 2 B0 1C 68 1 --- Control Change
0008E909 5 7 B0 1C 68 1 --- Control Change
0008E909 5 2 B0 3C 6B 1 --- Control Change
0008E909 5 7 B0 3C 6B 1 --- Control Change
0008E913 5 2 B0 1C 68 1 --- Control Change
0008E913 5 7 B0 1C 68 1 --- Control Change
0008E913 5 2 B0 3C 6D 1 --- Control Change
0008E913 5 7 B0 3C 6D 1 --- Control Change
0008E91E 5 2 B0 1C 68 1 --- Control Change
0008E91E 5 7 B0 1C 68 1 --- Control Change
0008E91E 5 2 B0 3C 70 1 --- Control Change
0008E91E 5 7 B0 3C 70 1 --- Control Change
0008E928 5 2 B0 1C 68 1 --- Control Change
0008E928 5 7 B0 1C 68 1 --- Control Change
0008E928 5 2 B0 3C 74 1 --- Control Change
0008E928 5 7 B0 3C 74 1 --- Control Change
0008E933 5 2 B0 1C 68 1 --- Control Change
0008E933 5 7 B0 1C 68 1 --- Control Change
0008E933 5 2 B0 3C 77 1 --- Control Change
0008E933 5 7 B0 3C 77 1 --- Control Change
0008E93D 5 2 B0 1C 68 1 --- Control Change
0008E93D 5 7 B0 1C 68 1 --- Control Change
0008E93D 5 2 B0 3C 7A 1 --- Control Change
0008E93D 5 7 B0 3C 7A 1 --- Control Change
0008E948 5 2 B0 1C 68 1 --- Control Change
0008E948 5 7 B0 1C 68 1 --- Control Change
0008E948 5 2 B0 3C 7C 1 --- Control Change
0008E948 5 7 B0 3C 7C 1 --- Control Change
0008E952 5 2 B0 1C 68 1 --- Control Change
0008E952 5 7 B0 1C 68 1 --- Control Change
0008E952 5 2 B0 3C 7E 1 --- Control Change
0008E952 5 7 B0 3C 7E 1 --- Control Change
0008E95D 5 2 B0 1C 69 1 --- Control Change
0008E95D 5 7 B0 1C 69 1 --- Control Change
0008E95D 5 2 B0 3C 00 1 --- Control Change
0008E95D 5 7 B0 3C 00 1 --- Control Change
0008E96B 5 2 B0 1C 69 1 --- Control Change
0008E96B 5 7 B0 1C 69 1 --- Control Change
0008E96B 5 2 B0 3C 01 1 --- Control Change
0008E96B 5 7 B0 3C 01 1 --- Control Change
0008E97B 5 2 B0 1C 69 1 --- Control Change
0008E97B 5 7 B0 1C 69 1 --- Control Change
0008E97B 5 2 B0 3C 02 1 --- Control Change
0008E97B 5 7 B0 3C 02 1 --- Control Change
0008E986 5 2 B0 1C 69 1 --- Control Change
0008E986 5 7 B0 1C 69 1 --- Control Change
0008E986 5 2 B0 3C 03 1 --- Control Change
0008E986 5 7 B0 3C 03 1 --- Control Change
0008E990 5 2 B0 1C 69 1 --- Control Change
0008E990 5 7 B0 1C 69 1 --- Control Change
0008E990 5 2 B0 3C 05 1 --- Control Change
0008E990 5 7 B0 3C 05 1 --- Control Change
0008E99B 5 2 B0 1C 69 1 --- Control Change
0008E99B 5 7 B0 1C 69 1 --- Control Change
0008E99B 5 2 B0 3C 08 1 --- Control Change
0008E99B 5 7 B0 3C 08 1 --- Control Change
0008E9A5 5 2 B0 1C 69 1 --- Control Change
0008E9A5 5 7 B0 1C 69 1 --- Control Change
0008E9A5 5 2 B0 3C 0B 1 --- Control Change
0008E9A5 5 7 B0 3C 0B 1 --- Control Change
0008E9B0 5 2 B0 1C 69 1 --- Control Change
0008E9B0 5 7 B0 1C 69 1 --- Control Change
0008E9B0 5 2 B0 3C 0F 1 --- Control Change
0008F5D5 5 2 90 53 00 1 B 5 Note Off
0008F5D5 5 7 90 53 00 1 B 5 Note Off
Let me know if you need more info?
We have progress!!!! Things work well when we work together!
Updated file with the PITCH and JOGS working!!!.......no Translator needed!!!!!
Still working at it but this is great news!! I hope to tweak the settings more later this evening
Outstanding now are:
- SHIFT commands (actually multi button selections do not work)
- Reverse button to work as a Censor button
- Utilizing loops 2 and 3 (not sure if VDJ supports multiple loops)
- LEDS don't work at all
- Scratching has a slight delay, we may be able to tweak it though
- Headphone cueing is not perfect but it works
<?xml version="1.0" encoding="windows-1252"?>
<midi version="5" date="24/01/2009">
<ctrl ctrl="24" mode="slider" action="crossfader" scale="0" />
<ctrl ctrl="12" mode="slider" action="level" chan="1" scale="0" />
<ctrl ctrl="18" mode="slider" action="level" chan="2" scale="0" />
<note note="37" action="play_pause" chan="1" />
<note note="56" action="play_pause" chan="2" />
<note note="36" action="cue_stop" chan="1" />
<note note="55" action="cue_stop" chan="2" />
<ctrl ctrl="60" mode="slider" action="scratch_wheel" chan="1" relative="true" scale="696" />
<ctrl ctrl="61" mode="slider" action="scratch_wheel" chan="2" relative="true" scale="696" />
<note note="83" action="scratchwheel_touch" chan="1" value="temporary auto" />
<note note="84" action="scratchwheel_touch" chan="2" value="temporary auto" />
<ctrl ctrl="13" mode="slider" action="pitch" chan="1" scale="0" />
<ctrl ctrl="19" mode="slider" action="pitch" chan="2" scale="0" />
<note note="42" action="hotcue" chan="1" value="1" />
<note note="61" action="hotcue" chan="2" value="1" />
<note note="43" action="hotcue" chan="1" value="2" />
<note note="62" action="hotcue" chan="2" value="2" />
<note note="44" action="hotcue" chan="1" value="3" />
<note note="63" action="hotcue" chan="2" value="3" />
<note note="42" action="loop_in" chan="1" value="1" />
<note note="61" action="loop_in" chan="2" value="1" />
<note note="46" action="loop_out" chan="1" value="auto" />
<note note="65" action="loop_out" chan="2" value="auto" />
<note note="43" action="loop_in" chan="1" value="2" />
<note note="62" action="loop_in" chan="2" value="2" />
<note note="47" action="loop_out" chan="1" value="2" />
<note note="66" action="loop_out" chan="2" value="2" />
<note note="44" action="loop_in" chan="1" value="3" />
<note note="63" action="loop_in" chan="2" value="3" />
<note note="48" action="loop_out" chan="1" value="3" />
<note note="67" action="loop_out" chan="2" value="3" />
<ctrl ctrl="17" mode="slider" action="bass" chan="1" scale="0" />
<ctrl ctrl="23" mode="slider" action="bass" chan="2" scale="0" />
<ctrl ctrl="16" mode="slider" action="medium" chan="1" scale="0" />
<ctrl ctrl="22" mode="slider" action="medium" chan="2" scale="0" />
<ctrl ctrl="15" mode="slider" action="high" chan="1" scale="0" />
<ctrl ctrl="21" mode="slider" action="high" chan="2" scale="0" />
<ctrl ctrl="14" mode="slider" action="gain" chan="1" scale="0" />
<ctrl ctrl="20" mode="slider" action="gain" chan="2" scale="0" />
<note note="38" action="key_lock" chan="1" />
<note note="57" action="key_lock" chan="2" />
<note note="78" action="browser_updown" value="+1" />
<note note="77" action="browser_updown" value="-1" />
<note note="79" action="browser_back" />
<note note="81" action="browser_enter" />
<note note="54" action="select" chan="1" />
<note note="73" action="select" chan="2" />
<note note="74" action="sample_play" value="1" />
<note note="75" action="sample_play" value="2" />
<note note="76" action="sample_play" value="3" />
<note note="50" action="reverse" chan="1" value="temporary auto" />
<note note="69" action="reverse" chan="2" value="temporary auto"/>
<note note="51" action="loop" chan="1" />
<note note="70" action="loop" chan="2" />
<note note="53" action="loop" chan="1" value="+50" />
<note note="72" action="loop" chan="2" value="+50" />
<note note="52" action="loop" chan="1" value="-50" />
<note note="71" action="loop" chan="2" value="-50" />
<note note="40" action="pitch_bend" chan="1" value="temporary +256" />
<note note="59" action="pitch_bend" chan="2" value="temporary +256" />
<note note="39" action="pitch_bend" chan="1" value="temporary -256" />
<note note="58" action="pitch_bend" chan="2" value="temporary -256" />
<note note="41" action="sync" chan="1" />
<note note="60" action="sync" chan="2" />
<note note="64" action="vinyl_mode" />
<note note="45" action="vinyl_mode" />
<ctrl ctrl="25" mode="slider" action="headphone_mix" invert="true" relative="true" />
</midi>
Moderators can you remove this post with the values I did previously so I can repost with decimal values instead of HEX, not even sure if it is really necessary to repost as I got the VCI-300 and VDJ working without any Translator.
Thanks
left jog
Yes... i think progress is moving fast :)
The reverse with the sencor button is just easy.
The main problem now that remains are the LEDS :)
Practice makes better...
It's odd that they have used a Control Change (CC) instead of Pitch Bend (0xE) for the pitch - Pitch Bend allows a 14-bit value to be sent in a single MIDI message, and is understood by the VirtualDJ general MIDI mapper.
The VirtualDJ general MIDI mapper does not currently support 14-bit CC's, but you can map to the MSB CC, which will give you a 7-bit value.
Perhaps a translator could be used to translate the 14-bit pitch CC to a Pitch Bend command, so you still get 14-bit precision (Important for pitch for accurate manual beat matching.)
That's good news - Please upload your MIDI map to the Tools plugins section once you are happy with it: https://virtualdj.com/addons/tools.html
It's not currently possible to map button combinations with general MIDI mapper.
A SHIFT button will only work if it physically changes the MIDI note/CC numbers while pressed, so that they can be mapped to an alternative action.
VirtualDJ currently supports one loop at a time. You could use the other buttons as hot cues.
This is not currently possible with general MIDI.
What action are you using for the sensor button? I can 't get it to work, as it does in ITCH.
But in my XML the sensor is working as reverse.Why is not working for you ?
It does something else in Itch ??? I dont remember :(
Anyways, i think we did both a fantastic MIDI MAPPER until now :)
My congrats and regards
Jim
<<<< JIM: the pitch is now very accurate with the latest mods on my XML from DjBeware :) >>>>
<<<< JIM: i have already posted my original XML in the tools area :) If DjBeware wants to upload his >>>>
<<<< modded MIDI MAP,its ok ,but i would like to ask him to put my name also in the description of the MAP >>>>
<<<< JIM: yes i also know that already - multiple key functions cannot be made in GENERAL MIDI >>>>
<<<< JIM: i just hope only for this now to happen - a native support from VDJ ,to turn the LIGHTS ON :)))) >>>>
One non-relative to this TOPIC, question, to JPBoggis: can you please remind with which buttons
on DN-HC4500 you can change the KEY of the song ? (not pitch)
Regards and respect
Jim
