Do you unplug your Maya 44 USB sc from the port that it's already pluged into? I had a gig on Sat. night and used my lappy for the first time. Installed the drivers for the sc and I was up and running in no time. I had a great night, no problems. The next night, I was setting up plugged the sc into the same exact port that I used the previous night and Deck 2 was going wild. Virtual tt was spinning with no song loaded. I un-installed and re-installed. I did this about 5 times. No luck. Now, I used a diffrent port and it worked.
Does this mean you cannot unplug the Maya after the gig? Is there a solution to this problem?
Syberman
Syberman
geposted Mon 26 Jan 09 @ 11:51 pm
anyone?
geposted Tue 27 Jan 09 @ 2:44 pm
Hi syberman, do continue on ur other thread that u have answer on it on the general forum. And pls do not double post on the same issue as it may cause confusion. Thanks;)
https://virtualdj.com/forums/103795/General_Discussion/Maya_44_USB_users.html
geposted Wed 28 Jan 09 @ 9:30 am
