hey i final hook up vdj to my cdj set up. but im still have a few problems ..
my first problem is, i cant control my cross fader. "its not moveing on screen" say i slide it to all the way to chanell one i can still here a lil of chanell 2 and vis versa. i am useing my mk2 mixer i am worndering if this has some thing to do with it because that also has a cross fader.
my 2 problem. is what is the normal latensy. when i press play some times i miss my cue point be cause of teh delay with vdj. im running vdj 3.4 right now
geposted Sun 01 Feb 09 @ 11:50 am
are you using the mk2 as a soundcard aswell?
if you are make sure your soundcard on the config menu is set to it :)
geposted Mon 02 Feb 09 @ 11:47 am
Hi rvd4now, why don't u try and download/use the recent v5.2.1. This version have improved greatly than V3.4;)
Do u use external mixer too along with ur cdj?
geposted Mon 02 Feb 09 @ 2:26 pm
Pls do not double post. This cause confusion.
I just stumbled across ur other post. Pls continue there.
https://virtualdj.com/forums/104035/Hardware_Technical_Support/i_did_it_but.html
geposted Mon 02 Feb 09 @ 2:53 pm
