Forum: VirtualDJ Plugins
Topic: DENON DN-S1200 MIDI Mapper update
This Mapper has been uploaded. Just waiting for It to be approved!
Description:
Changes In Mapper:
-Cue Butoon deck 1 & deck 2--------Play_Stutter back to the cue point
-Play/Pause button deck 1 & deck 2 --------same
-Echo/oop Button deck 1 & 2---------synch
-Flanger Button deck 1 & 2-------Pitch reset with reset checked---meaning once pressed back to o% Pitch
-Filter Button deck 1 & 2----Synch_nocbg
-A1 button-Play Stutter Auto deck 1 & 2-----Play & synch song from the other deck for mixes
-Next Track Button 1 & 2-----select O Active deck---select Active deck and Cueing deck
-Tap Button 1 & 2-----Manually fix the BPM by tapping the beat.
If "Smart BeatTap" is activated, the grid tapped will automatically be snapped to the nearest likely grid.
Title/ID3-UTIL.-----Video_Open- Activate Video open and close video screen
-Flip Button deck 1 & 2----Go_to cue point
-A2 Button deck 1 & 2----Loop In Auto--hit to mark starting point of the loop
-B Button 1 & 2----Loop out-hit to activate that loop point marked and the end of the loop
-Exit/Reloop Button---Loop_Exit
-Time/Cont/single Button deck 1 & 2---Set_Cue point
Minor bug.Pitch Slider Button Is corrected
New functions:
A/B Trim Button----Switches between Active and Cue deck
Quick Jump/Fast Search Button Left and Right---Move into the song foward and backward with minimal audible sound
Interuptions
Disc Eject Button------Clone what is playing on the Active deck to the default deck.
Everything else are the same like the old mapper
Denon DN-S1200 midi mapper
Author: RonnieB
geposted Wed 04 Feb 09 @ 5:42 pm
I want to connect the denon 1200 to the pc and use the NUMARK DJ|iO as the soundcard.
The reason i want to do this is so i can switch from cd to usb without the program crashing. Can anyone gguide me on how to do this.
Please open your own new topic on this subject rather than bumping an old topic from 2009.
Click on the pen and paper icon in the main topics list to open a new topic.
You will also need to purchase the full VirtualDJ Professional to be able to use the Denon DN-S1200 and/or external sound cards: http://www.virtualdj.com/buy/index.html
[Old topic closed]
