I'm almost timed up on my trial... I'm intending to purchase VDJ but I need to use it on a different computer to the one that I'd use to download it. I'm reluctant to connect my work PC (when I get it) to the net. The trial wouldn't work on my existing work PC. So will I be able to download the full VDJ product to disc on one PC then instal it on another?
I've trialed all the systems I could find and VDJ is the best by far.
Thanks in advance if anyone can help with my question.
geposted Fri 25 Feb 05 @ 10:34 am
Yes, you could put the file onto disc, make a note of your serial number, and then install it on your work PC.
No hassle in doing so.. just remember to came back here with you Pro user status and ask if you have any troubles
Steve
Steve
geposted Fri 25 Feb 05 @ 1:08 pm
VDJ's the best you're right.
You can use the same license to use VDJ on all PC you work with BUT other people cannot use your installed VDJ software.
Welcome in advance as a full and very happy user ;-)
geposted Sat 26 Feb 05 @ 3:31 am
Thanks for the help.. have now downloaded the product and will put it onto my work PC when I get it
Paul
Paul
geposted Sun 27 Feb 05 @ 3:31 pm
Welcome aboard ;)
geposted Sun 27 Feb 05 @ 3:43 pm
Welcome ... Happy Mixing
geposted Sun 27 Feb 05 @ 8:06 pm
Welcome.....you made the right choice
geposted Sun 27 Feb 05 @ 8:50 pm
