I think it will be useful to manage the level of the effects from VDJ (not only with the plug-in itself)
Like that, we can mix the original sound with the sound modified very precisely.
Very simple idea, isn'it ?
What about devellopment ???
geposted Fri 25 Feb 05 @ 12:27 pm
I don't really agree with your wish.
Maybe tell which effects you want to be modified.
Most effects which transform the signal has a level slider.
geposted Sat 26 Feb 05 @ 2:54 am
I know it, but try to use every effect with short cuts, and after I think you will change your mind.
Because the volume slider of each effect is not the first one, you have to use the mouse.
With VDJ, you can only manage the first slider with whortcuts, and I noted that this shortcuts does not work. You can not modify the level, only indicate the volume.
It is the same problem as for management of sample level by shortcuts
The alternative is to modify the effect by myself.
DJCEL suggested me to do it, because he agrees with me about this topics.
I am going to learn to modify effects with him
Is it really a big problem to create a cross fader for effects?
geposted Sat 26 Feb 05 @ 3:24 pm
yes , an Wet/Dry slider for effect
geposted Sat 26 Feb 05 @ 5:54 pm
It only depends on the plugin. Sometimes there is a slider volume which is your slider wet/dry in fact
geposted Mon 04 Apr 05 @ 2:16 pm
