Hi,
i know that there are a couple to DMC-1 mappers available for download, but is there one that can handle the a video transition?
On the DAC-2, the preview button can be used to perform this action. I use the DMC-1 with VDJ 5.2.1 and work with videos all the time, so it would be great if there is a plugin that would allow me to use preview to perform the same action.
Is this possible already?
Many thanks for any advice,
Mark
Mark
geposted Mon 09 Feb 09 @ 7:57 am
I can do a version of my DMC mapper with this. But then you have to loose one function since all button combinations are already in use.
geposted Tue 10 Feb 09 @ 12:56 am
That would be great, thank you. I am not worried about losing some functionality as all I use is play, cue/stop and hopefully the preview button!
Thanks,
Mark
Thanks,
Mark
geposted Tue 10 Feb 09 @ 3:53 am
Do you know, is it possible to run DMC-1 on the Mac version of VDJ using a Serial-to-USB adapter? I had the DMC-1 working on PCDJ Red VRM before I switched to the Mac, I'd love to have the controller back.
geposted Wed 04 Mar 09 @ 11:09 pm
No, it is not possible.
geposted Thu 05 Mar 09 @ 2:37 pm
