Would anyone find this useful? Select your effect, select the LENGTH of time to have it run for (1 beat, 4 beats, 2 seconds - I don't know) so you just just hit "ACTIVATE" and not have to worry about actually turning off the effect? You know it will only effect the song for 4 beats, and you can concentrate on mixing.
geposted Sat 26 Feb 05 @ 11:28 pm
That's a good idea. I sometimes find that I wish I had that when I mix...
MS
MS
geposted Sun 27 Feb 05 @ 2:46 am
Good Idea. id like to see that added
geposted Sun 27 Feb 05 @ 8:49 am
Like define how many times we can play a loop, a sample ,effect on/off
Would be very cool
Andre
Would be very cool
Andre
geposted Sun 27 Feb 05 @ 12:40 pm
We could implement it in the plugins codes ...
Ask the creators for the effects wou want to have this feature.
It's a good idea.
It's a good idea.
geposted Sun 27 Feb 05 @ 2:15 pm
I begin to use a little file in Effect folder to save data of my plugins and macourteau did it for all his plugins i think
geposted Sun 27 Feb 05 @ 4:45 pm
Good idea djcel.
Indeed I'm wondering if it's possible to use the same config. file for all plugins with different areas inside. Could it be possible ?
geposted Sun 27 Feb 05 @ 4:53 pm
it could be possible. Have a look inside the xml file of macourteau: there are data for 3 or 4 of his plugins.
I prefer don't touch this file because if someone does a mistake, it could be erased some other date.
Maybe use the same idea of xml but one file for each author. Maybe we should define a generic name as "data_plugins_djcel.xml".
geposted Mon 28 Feb 05 @ 8:21 am
