Heya people, can anybody tell me if u have problems using a laptop with time code vinyls? also if u can write your setup.
geposted Sun 27 Feb 05 @ 12:14 am
I use a laptop with TCV and I have had NO problem at all. It's a Dell 4150 Pentium 4 1.8 Ghz 768 MB Ram. 40 Gb Hardrive @ 5400 RPM. I think the faster Hardrive helps alot. As does the processor and Ram. You can see my videos in which I'm using my laptop and TCV.
geposted Sun 27 Feb 05 @ 1:05 am
Thanks, I have problems using my Acer Travel Mate (celeron 2.0 GB, 512 Ram, 20 GB HD) when I use the TC with my laptop it's start to gettin slow, and when one song is playin in a desk and I load another in the other desk the laptop freezee for a seconds many times, until the load is complete in desk. Any Suggestion???
geposted Sun 27 Feb 05 @ 3:14 am
Check for power management and disable if possible.
geposted Sun 27 Feb 05 @ 3:55 am
I'd say don't have beatlock on if you do by chance. I know TCV does NOT world with Beatlock at all. It just freezes the program. Also you could try changing your max load.
geposted Sun 27 Feb 05 @ 3:57 am
Wich OS are you using on your lap???
geposted Sun 27 Feb 05 @ 4:36 pm
