Is anyone else having a problem with VDJ 5.2 and the Xponent jog wheels? Touching the side of the wheel no longer acts like a jog. It acts as if in "scratch mode" whenever it is touched. I am using the Xponent mapper from SBDJ, version 1.31.
geposted Sun 15 Feb 09 @ 2:16 am
Can anyone describe for me the problem in version 1.30 of the Xponent mapper that was fixed in 1.31?
The changelog shows:
1.31: Fix problem with jog bending in scratch mode
geposted Fri 13 Mar 09 @ 3:58 am
I will have a look at it tomorrow...
geposted Fri 13 Mar 09 @ 8:52 am
I seem to have messed something up somewhere; will fix and repost :)
geposted Sun 15 Mar 09 @ 9:09 pm
OK, schoolboy error - || instead of &&. Problem resolved - I'll recompile for PC and Mac and upload v1.32 some point this week.
geposted Sun 15 Mar 09 @ 9:30 pm
Thanks SBDJ! I thought I was losing my mind! While this may still be true, can't wait for the next mapper release. I appreciate your continued support of the Xponent.
Regards,
Troy
Regards,
Troy
geposted Mon 23 Mar 09 @ 3:59 am
I'M HAVING THE SAME PROBLEM. ITS DRIVING ME NUTS. Everyting was working fine until it upgraded to VDJ 5.2. Now its doing exactly what you described here. What am i to do??
geposted Tue 07 Apr 09 @ 6:03 pm
https://virtualdj.com/addons/4091/M-Audio_Xponent_Mapper.html
Just so you guys are aware SBDJ has no uploaded the latest version of his mapper - this may fix your problems.
geposted Tue 07 Apr 09 @ 6:11 pm
My mapper is only available to professional edition users; anyone else has obtained it illegally and won't get any support from me.
geposted Tue 07 Apr 09 @ 6:40 pm
I just downloaded and tried it out with VDJ Pro 5.2 and it works GREAT! My issue is resolved! Thanks alot SBDJ! Great Work!
geposted Fri 10 Apr 09 @ 1:06 am
No problem :)
geposted Fri 10 Apr 09 @ 6:26 am
