Could someone make a plugin, which the camera picture filters, cut to a single context (which is granted), and some effects to the place?
In fact, in a blue box
example this:
(but here the dj is only a picture...not an live video)
example this:
geposted Tue 24 Feb 09 @ 10:46 am
You mean like an alpha color, and remove say all background from an image with a person in it? (like your example)
If so, there is already such a plugin:)
But you need to have a clear one colored background :)
geposted Tue 24 Feb 09 @ 10:49 am
as is shown in the picture, it's made with a pluginnal ...
but for me it's a live video image to be ... such as a webcam image!
geposted Tue 24 Feb 09 @ 10:54 am
but if there is such a plugin, then what's that name?
geposted Tue 24 Feb 09 @ 10:57 am
http://www.virtualdj.com/addons/2929/ShowLogo.html
This can be used for your purpose..
I think some other plugins have similar alpha channel features
geposted Tue 24 Feb 09 @ 11:04 am
yes! I used this plugin, but it can only picture, not video!
Live video, like ...
we do not understand this?
i like a motion picture... not a moment pic...
geposted Tue 24 Feb 09 @ 11:08 am
there used to be such a plugin at beta testing ..
Will ask around and see where its at now :)
geposted Tue 24 Feb 09 @ 11:16 am
The "backdrop"plugin can be used for this. fills the screen with an image, and allows you to size the master video into the spot and size you want it. I use 4 instances of this for pomoing the style of music thats comming, including one that shows the video appearing on an IPhone, and the promo text around it.
http://www.virtualdj.com/addons/2590/Backdrop.html
geposted Wed 25 Feb 09 @ 11:10 pm
I should be the other way round ...
Thus, the picture is about living in the mobile video clip
No one familiar with the term blue box or green box!? Than what is used in meteorology...
geposted Thu 26 Feb 09 @ 5:07 am
Anyone else?
geposted Mon 02 Mar 09 @ 9:38 am
May be a "show your logo" plugin modified to insert a picture of not only the camera but also the image?
I think that the logo instead of the camera image would be present in the background of the video clips ...
it is possible?
It may be a solution? Can someone do this?
or transformed by the plugin
it is possible?
geposted Tue 03 Mar 09 @ 4:32 pm
