I would like to try and develop or modify a skin or two, is there a software program i require to get started?? any help would be appreciated.
geposted Thu 03 Mar 05 @ 10:18 pm
I don't develop skins but as far as I know you only need an image editing program and a text editor, that and be able to follow the instructions in the skin developers SDK. Skin developers, correct me if I am wrong.
geposted Thu 03 Mar 05 @ 10:34 pm
Skins are fun, all you need is paintshop and notepad...you already have both
geposted Fri 04 Mar 05 @ 12:08 am
Also, a validating XML editor might help catch errors but it's certainly not needed. An image program and a text editor is all you need and as Cyderhouse already mentioned, you have both included in windows anyway. However, I might recommend an image editor that's a little more "friendly" than paintbrush.
geposted Fri 04 Mar 05 @ 1:54 am
I recommend taking a couple of skins and picking them apart by looking at the graphics and seeing how the XML tags provide function to the image (skin)
plus, you can always find help from people in the Skin forum
Best of luck, cstoll
geposted Fri 04 Mar 05 @ 3:01 am
