Hey guys,
i have a quick question. Im thinking of picking up some CDJ 400's and was wondering if i connect them up to VDJ does the sound come back through to the CDJ or do i need to connect the sound from the computer to my mixer?
sorry for the crap description. just need to know exactly how it works.
thanks
thanks
geposted Mon 02 Mar 09 @ 7:41 pm
External soundcard required or sound from PC. The CDJ400's are a midi controller only - they do not have a built in soundcard.
geposted Mon 02 Mar 09 @ 7:51 pm
i read in the link below that the cdj 400's of asio sound cards in them.
http://forums.pioneerdj.com/eve/forums/a/tpc/f/8191012904/m/2301008955
geposted Mon 02 Mar 09 @ 8:27 pm
https://virtualdj.com/forums/103781/MAC_Version_Technical_Support/Macbook___VDJ_5_2_1(just_bought_it)___CDJ_400_s___DJM_400.html?page=1
Hopefully this will answer your question.
geposted Tue 03 Mar 09 @ 12:12 am
I have been using this setup (2* cdj-400 and virtual dj) for almost a year now and the cdj-400s have a build in soundcard.
geposted Tue 03 Mar 09 @ 10:35 am
Sounds like i'm wrong then - i stand corrected.
I dont own the 400's but know someone that does and he has always used an external sound card with them so i just assumed you needed one. My bad -
geposted Tue 03 Mar 09 @ 10:57 am
how does the setup go with the cdjs? was it easy to setup? sound quality all good?
geposted Tue 03 Mar 09 @ 10:32 pm
can you use 2 cdj400's in their usb midi mode or are you in some sort of timecode mode??
geposted Sat 07 Mar 09 @ 10:51 am
You can use 2 in MIDI mode.
geposted Sat 07 Mar 09 @ 12:00 pm
what does that involve/how does it work??
geposted Sat 07 Mar 09 @ 2:48 pm
2 cdj400's - 2 usb cables - 2 usb ports - 1 computer
just activate the remote control in the config section
Please register your serial to have access to all the goodies.
geposted Sat 07 Mar 09 @ 2:51 pm
yah im just trying to get my setup figured out first
geposted Sat 07 Mar 09 @ 3:20 pm
