how do i burn my mix and how am i supposed to cut tracks , while mixin 2 songs succsesfully
geposted Fri 04 Mar 05 @ 7:10 pm
Tony, what version are you using? The record options are easily accessible and options are there to automatically cut tracks while you DJ and the option is also there to record to a ready to burn CD file. This is also well documented in the manual.
geposted Fri 04 Mar 05 @ 7:30 pm
tony the tiger
The version you are using (1.06) is painfully outdated. And of course no longer supported.
Please uninstall this poorly cracked outdated version and try the latest trial version. If you still have questions, help will be easier to offer on a newer (legal) version.
geposted Fri 04 Mar 05 @ 10:03 pm
