Hi,
I have VDJ 5.2.1 for Mac OS X and a Numark Omni control.
I have used the available midi mapper to get the omni control to function, however the headphones do not seem to play. Is there something I'm missing?
Also, I have to load the midi mapper each time, it won't save when I close VDJ, again am I missing something obvious?
I am used to using VDJ on a PC, but have recently bought a MacBook, so am not fully aquatinted with running it on OS X.
Thanks for any help,
G
G
geposted Wed 11 Mar 09 @ 8:23 pm
I am having similar problems. I get both the main and cue mies in the headphones at all times. None of the lights on the OMNI Control work. Traktor LE (included on the Omni Control CD) works perfectly. Maybe we just have to wait for native support?!
geposted Fri 20 Mar 09 @ 1:29 pm
Hi currently VDJ cannot send midi data to control the lights, native support will be added in the next version.
geposted Sun 22 Mar 09 @ 8:28 am
Can't wait for that next version!!
geposted Sun 22 Mar 09 @ 8:48 am
hey all
i just need version supprted with omni control thanx all
geposted Mon 02 May 11 @ 10:12 pm
Numark OmniControl is natively supported in the latest full VirtualDJ Pro: https://virtualdj.com/products/virtualdj/
NOTE: Only the full VirtualDJ Pro supports MIDI controllers. You can try it out for 10 minutes at a time in VirtualDJ Home FREE: https://virtualdj.com/download/free.html
geposted Wed 04 May 11 @ 5:49 am
