Does anyone know if I can take a skin from my Mac and put it on my PC and use the skin resizer tool to resize the skin to the appropriate size and then put it back on my Mac? I want the original skin in 1440x900 for my Macbook Pro and there aren't really any options for that except a few but they don't work well for me. Any help is greatly appreciated.
geposted Thu 12 Mar 09 @ 5:17 pm
Yes you can do that.
geposted Thu 12 Mar 09 @ 5:48 pm
Is it easy to do once I download the skin resizer tool or is it difficult? Will it look good and work well once I do it? Thanks.
geposted Thu 12 Mar 09 @ 9:36 pm
The tool itself works well and is easy to use - however not all skins are resizable - best off trying it and seeing what happens.
geposted Thu 12 Mar 09 @ 9:55 pm
