I for some reason cannot get the Clipbank Random Video to work/install my laptop. I have updated the directx and ms C++ from the other post that SBDJ made but for the life of me I can't figure out why I can't get the Clipbank Random Video plugin to work on the laptop. Any clues?
The plugin shows up under video effects but the box at the bottom is grey and there are no controls listed on the right like there are with other plugins.
Thanks!
Thanks!
geposted Thu 12 Mar 09 @ 6:59 pm
if you have tried to activate it without success, how about deleting it completely from your system and do a reinstall, i have had this problem but with other plugins i've installed recently and that's what i intend to do, just haven't getting round to doing it yet.
lets know the results if you can, unless of course someone can advise another way.
geposted Thu 12 Mar 09 @ 8:07 pm
How do I uninstall it? I couldn't figure that out.
geposted Thu 12 Mar 09 @ 9:14 pm
go into vdj folder and delete...
geposted Fri 13 Mar 09 @ 6:42 am
Ahh okay. I'll give that a try and then reinstall. For some reason it works on my desktop (don't use for djing just regular computer work) just not on the clubs computer or my laptop.
geposted Fri 13 Mar 09 @ 7:47 pm
