Hi Guys!!!
Ok here is this weeks problem...... I work in a club where they have just installed 2 nice new shinny cdj400!!!! I know that I can plug these units directly into my lapy (macbook white) but :
1/ which sound setting do I need
2/ how do I set the midi on the cdj to midi 2
then I want to use my denon 2500 for other clubs, the problem I'm having with this one is the same again
1/ which sound setting do i need
all i seem to be getting out of the denon is 1 channel in split mono (so deck 1 is playing deck 1 audio from left and deck 2 from right)
any help would be great and I think what would be better is if you had an idiot guide on this sit somewhere to tell us how to set these things up like a page for each controller.
p.s. still waiting for the Karaoke rotation plug-in for the mac version...... thinking that I should of bought pcdj and a windows machine
thank for your help
thank for your help
geposted Sat 14 Mar 09 @ 5:55 am
I take it that no body has the links or actually knows what the setting should be with a mac then?????????
geposted Mon 16 Mar 09 @ 6:09 am
Not having one of these myself i coudlnt categorically say but i would think you will need some kind of split out and then select the CDJ soundcards.
This may help: https://virtualdj.com/forums/104602/MAC_Version_Technical_Support/Mac_version_And_%3Cspan%20style=
(or not as the case maybe)
I too am still waiting for this. Apparently it isnt as simple as you may think to port the app to Mac. As it required DirectX which is Windows based. I hope they are working on a Mac equivalent of this and the "Titler" plugin.
geposted Thu 19 Mar 09 @ 5:53 am
Thanks for your help fella!!!!!!! Very much needed
But have just noticed that the thread you posted wasn't for getting them working in version 6
Ta Anyway
Ta Anyway
geposted Tue 16 Jun 09 @ 3:51 pm
