hi there just wonderd if there is a way to keep the video screen playing disco light (or something of the sort) while playing mp3s. is there any pluggins we can use so this is possible.
geposted Sun 15 Mar 09 @ 10:33 pm
As far as I know the choices at present for visuals when using an audio file are:
Sonique
Clipbank
Slideshow
Camera
These are all available in the professional edition, I don't know what is included in your version.
Sonique
Clipbank
Slideshow
Camera
geposted Sun 15 Mar 09 @ 10:41 pm
if you go into the vide tab in config at the bottom there is a drop down box "use this when playing audio" see what selection is availble to you, select and tick the box to the left to try out.
geposted Mon 16 Mar 09 @ 4:42 am
hi again. tryed all ur sugestions and i still just get the plain black screen :( .
geposted Mon 16 Mar 09 @ 3:51 pm
in the video tab just underneath where it says video output tick the box that says activate, to the right choose your video card from the drop down window...
geposted Mon 16 Mar 09 @ 7:29 pm
its not giving me the option to choose my video card.
this is a screen shot:
http://i418.photobucket.com/albums/pp266/DjMARZY/vdjshot.jpg
geposted Mon 16 Mar 09 @ 10:30 pm
sorry marzy that option is when you have an external monitor connected. you want to tick the box "decode when hidden" helps when doing transitions.
geposted Tue 17 Mar 09 @ 2:21 am
i did this tutorial for a guy the other day and he got his soniques going for the first time, can you try it and lets know how you get on...
http://www.virtualdj.com/homepage/tayla/blogs/3512/Using_Soniques_For_The_First_Time.html
i could possibly make a video if you get stuck.
geposted Tue 17 Mar 09 @ 2:26 am
hi again. i do conect other screen sometimes i will try conecting to my screen to see what happens and il fallow your tutorial to. il post a reply after. thanks for the help.
geposted Tue 17 Mar 09 @ 4:15 am
no probs mate,
geposted Tue 17 Mar 09 @ 4:37 am
im back lol. tryed conecting my screen and using ur tutorial it seems to be working (i think) lol. 1 prob do i need to download sonique effects(.svp) fils and if so can u say where can i get them. thanks.
geposted Tue 17 Mar 09 @ 8:24 am
hehe, was gong to mention that earlier, not sure if you can to be honest, go to top of page and hover your mouse over download come down to plug ins then across and down to video effects i think it's on the first page... goodluck
if you have no luck there you could try using clipbank for audio only files, i make a few (ads, clips etc)so get back to me if your stuck
geposted Tue 17 Mar 09 @ 8:44 am
if you have access to sonique files get the one on the fifth line down it has 72 effects, this is the best one, has all the crappy stuff deleted out for you,
geposted Tue 17 Mar 09 @ 8:48 am
damnn. "Your current licenses do not allow you to download Video Effects". hahhaha im naffed lol.
geposted Tue 17 Mar 09 @ 9:35 am
can you use clipbank, if you can send me your email by pm and i let you have access to my clipbank stuff.
geposted Tue 17 Mar 09 @ 10:02 am
i dont no what that is lol. djmarzy@hotmail.com
geposted Tue 17 Mar 09 @ 10:06 am
open up vdj and select the tab marked effects > open video effects tab > look down the left column and select clipbank if it's there, now select it when this happens you should see 12 squares to the bottom right of screen. in the middle of the screen there is a box named activate, click on this and it should turn blue.
if you could check this straight away as i have to pop out, but i should be back within the hour.
geposted Tue 17 Mar 09 @ 10:30 am
yes i have this. if ur busy just help me out when every its best im in no rush lol.
geposted Tue 17 Mar 09 @ 10:33 am
i carnt see ur last reply :S lol. im new on this site ibet u guessed.
geposted Tue 17 Mar 09 @ 10:54 am
hi, i've been informed the legal copy of the le software which you have can't play videos, think your gonna need an upgrade i'm afraid.
geposted Tue 17 Mar 09 @ 11:59 am
