Hi all i got a prob: when i'm switching crossfader too fast on left or right on my RMX, crossfader on VDJ stay's a little bit off of the max value:/ Enybody knows why? If i need to calibrate RMX with VDJ how to do it?
Greets
Greets
geposted Tue 17 Mar 09 @ 6:03 am
Yes, I'm having the same problem too!
I wonder if it's VDJ or RMX problems....pretty much the EQ knobs and Cross Fader on the VDJ don't exactly match the RMX.
It's really frustrating what you slide the fader all the way on the RMX but VDJ still leaves partial room and u can't do anything except to slide back slightly and redo it again.
anyone?
anyone?
geposted Thu 19 Mar 09 @ 9:19 am
Only what we can do it's gentle fadeing on next channel.. only then crossfader works good.. but when u need fast go to another channel he stock in+/- 80% on 2nd channel O.o ..and knoobs.. yeah if they are on 0 and i try to slowly turn them for max <for example bass> they are working when knoob is on 10%! i don't have smooth control on my knoobs:/ <bass killed.. and in one sec boom i have bass> lolz
geposted Fri 20 Mar 09 @ 6:22 am
