Forum: Asian Forum - Topic: RMX driver error? [SOLVED]
(Bahasa indonesia, mandarin, melayu, etc...) Selamat datang ke forum VirtualDJ. Di sini kamu boleh berbincang atau bertanya tentang apa-apa yang kamu ingin tahu. 欢迎到VDJ。 这里我们能谈论了什么您需要知道节目。
VirtualDJ Forum
Asian Forum
RMX driver error?...
Autor - Topic: RMX driver error? [SOLVED] -
isz_rmx
Limited edition user
Posted Tue 24 Mar 09 @ 1:33 pm
Hi SpinnaJ,
Just got my own decks! :) a used sl1200 mk2.
Anyways, when i connected it to the rmx (with normal vinlys), i noticed that the sound sometimes would play only on one side. Speakers AND when cueing on headphones. After some trial and error, i noticed that closing and re-opening the DJ console control panel (on the system tray) would solve the problem.
So then i decided to update it from the herc website, since i saw the update has a bug fix for ASIO.
After updating it, my laptop doesnt recognize the console anymore! ive searched for some solutions on the net, but neither worked.
Any advise?
Thx
spinnaJ
Moderator
(mac beta tester)
Premium Member
Posted Tue 24 Mar 09 @ 4:36 pm
Hi isz what is ur current sound config?
isz_rmx
Posted Tue 24 Mar 09 @ 9:25 pm
Hi Spinna,
Sound Config? still using the VDJ LE, dont think i have any settings, as for the ASIO settings in the system tray, i couldnt open it.. think it needs to be connected to the RMX to show the settings. Its not detecting, so i couldnt open it.. :(
isz_rmx
Posted Tue 24 Mar 09 @ 9:30 pm
oh ya, i originally thought it was the decks, coz the rca cables was changed. (not soldered but has been cut and taped!) then i changed it from input 1-2 to input 3-4, and it worked. so i guess it must've been the console.
But sometimes, it works. does this make sense?
Just thought u shud know.
spinnaJ
Moderator
(mac beta tester)
Premium Member
Posted Wed 25 Mar 09 @ 1:10 am
Hi isz,, try to use our legit demo from this site.. it can be use for 20 days. As i mentioned previously, there i a limitation for the VDJ LE version. Try it and let me know. You should not have any problem;)
isz_rmx
Posted Wed 25 Mar 09 @ 1:53 am
Hi Spinna,
Thanks for the advice, but i thought it has something to do with the drivers i downloaded from the hercules ftp site..
Anyways, ill uninstall everything and try to install the drivers with the demo version of vdj again.
Will tell u how it goes.
thx
isz_rmx
Posted Wed 25 Mar 09 @ 12:32 pm
Sorry for the false alarm bro, i found out it was the RCA cables.. i played around with the taped cables and presto! it worked!
Now i gotta tape it again. :p
ill get new rca cables and try to solder them in soon.
Thanks!
PS: i tried installing the downloaded driver but failed.. well i guess i dont have to update anymore! it works like a charm!
spinnaJ
Moderator
(mac beta tester)
Premium Member
Posted Wed 25 Mar 09 @ 1:17 pm
If it ain't break, don't fix it;)
Nice to hear it solved;)
