i just purchased this and new to this fourm and i was wondering if i could use my dns 5000s with this program
geposted Tue 08 Mar 05 @ 2:49 pm
Yes, that's possible. Dowload the Timecode mp3:
http://www.virtualdj.com/products/timecode/
Burn it as an audio CD. If you have a proper sound card with Asio support (like audiotrak Maya Usb) Attach your Denon player to this card. Set up the config correctly and off you go.
Ewout
Ewout
geposted Tue 08 Mar 05 @ 6:54 pm
now here is my next problem.i get one of my 5000s to work but the other just will not act right. i have two SB live cards install with no conflits and they both are outputted to my mixer(x1500). now the thing that get me is that they are both set up the same way but (deck1)one had to have the invert phase check and it will not back spin the only thing it do is speed forward. also it will not cue.(deck2) lock the cue it lets me loop but the scratching is late not like it should be, i cant chirp, baby scatrch back to back nor transform(thats way out ) but if you or any1 wi9th the same can lend me a hand that would be great.
geposted Wed 09 Mar 05 @ 5:52 pm
