Hi,
In VDJ Pro 5.2.1 my Cue <> Mix slider for my headphones doesn't work properly.
When I slide it to "Cue", I hear the song that is actually playing (through the speakers) in my headphones. What I want here, is to prelisten my next song. Only if I slide it to "Mix", I can prelisten the next song, but without hearing how the mix would sound like.
In VDJ LE it all worked correctly. With the slider on "Cue" I could prelisten the next song. With the slider on "Mix" I could here how it would sound when I mixed both songs.
Does anyone have a solution for this problem?
Thanks in advance.
Thanks in advance.
geposted Sat 28 Mar 09 @ 5:55 am
You need to set a shortcut with headphone_mix key.
geposted Sat 28 Mar 09 @ 6:14 am
Can you tell me how i can do that? I've only got the Pro version since yesterday... :-)
Thanks
Thanks
geposted Sat 28 Mar 09 @ 6:55 am
Do you have an external MIDI controller?
If so, click on the Config menu, Remote Control tab, enable General Midi option, click on Add, All, heaphone_mix, move the knob/slider that you wish to link to this feature and the word AUTOLEARN should disappear by showing the control of your MIDI controller.
The work is done.
The work is done.
geposted Sat 28 Mar 09 @ 7:08 am
Thanks for your help :-)
I do have a console, however, I don't think that's the problem.
When I use the slider in VDJ with the mouse instead with the button on my Hercules rmx, it gives the same problem.
I tried your solution, but I still have the same problem.
geposted Sat 28 Mar 09 @ 7:33 am
Reading it, I suggest you to communicate straight with support for telling them about your problem
https://virtualdj.com/contact/
You are welcome.
You are welcome.
geposted Sat 28 Mar 09 @ 7:38 am
