Is it possible the team of Virtual Dj create a plugin called Now Playing? it would be a a plugin that makes you able to make advanced "Now Playing" calls, to FTP servers, through HTTP requests and saving in local files another words an ease-to-use tool for Virtual Dj, that allows the world to see what you're listening to right now, through FTP, HTTP and local saves!, like Now Chriping for the Songbird app if you have no idea what I am talking about view it here:http://snipurl.com/ideaforvirtualdj . It would be great and make your application a bit more flexible then the others.
with kind regards,
Efrain
with kind regards,
Efrain
geposted Mon 30 Mar 09 @ 10:15 pm
