Hi, beim Start von Virtual DJ 1.09 (war beigepackt bei der Hercules DJ Console) erscheint folgender Fehler:
"Fehler im DirectX Soundtreiber"
Hat jemand eine Idee?
DANKE --> DJ Kurt
Hi, if I would like to start Virtual DJ 1.09 (come with Hercules DJ Console) I get the follow errormessage:
"Error with the DirectX Souddriver"
Is there any who can help?
THANX --> DJ Kurt
DANKE --> DJ Kurt
THANX --> DJ Kurt
geposted Sat 12 Mar 05 @ 4:49 pm
I would like to remove the the song on a sing an keep only the intrumental music . how I have to do?
thanks
thanks
geposted Sat 12 Mar 05 @ 4:53 pm
@hiku1966
maybe you are trying to use ASIO with your sound card or maybe there is a problem with your sound card
Ich glaube, dass es eine Probleme mit Soundtreiber ASIO or Sound Karte ist
geposted Sat 12 Mar 05 @ 5:07 pm
Bparis : Just find yourself the instrumental, it's the only descent way
Greetz Dasouth
Greetz Dasouth
geposted Sat 12 Mar 05 @ 6:23 pm
@hiku1966,
Are you using the Hercules sound card, when you get the error? Then this post should be in the Hercules forum.
There are some problems with the Hercules Asio drivers. Make sure you install the latest drivers from the Hercules site.
Ewout
Ewout
geposted Sun 13 Mar 05 @ 2:29 pm
Hello!
When starting VirtualDJ leave it in normal mode, and when it loads then switch to DJmode.
Lass die konzole in normal mode und starte VDJ, ven es funktioniert dann shalte uber in DJ mode.
geposted Sun 13 Mar 05 @ 10:43 pm
