Forum: Old versions
Topic: ASIO: "not enough channels"
I have a dj i/o interface with vdj that im running and 2 cdj 800's... I have all the right connections and the interface was installed correctly but I still get this error message ASIO: not enough channels.... please somebody help, I have a gig tomorrow... also the timecoded cds play correctly
geposted Thu 16 Apr 09 @ 12:54 am
The DJ I/O does not have any inputs to use timecodes.
Remember to register your version of VDJ!
As already said, you can't have hooked it up correctly because the DJ I/O only has a mic input. Hence the error message "Not Enough Channels" - there aren't enough input channels for a timecode setup.
You will need a better soundcard I'm afraid.
Also note that the demo version limits timecode use to 5 minutes IIRC.
Hello people, I have 2 cdj 1000's and am trying to get the times codes to work i have burnt the pro discs as i know that these are the ones i need to use, the problem is i cannot get it to config properly as all i get is interference and lots of noise but no control what so ever, also the maya soundcard is being detected but then says i dont have enough channels
help please
hello i just bought the dj io soundcard and it says the same thing not enough channels!! so i was wondering what sound card do i need ???
You need a 4 in/4 out sound card like the Numark virtual vinyl interface, maya usb 44, or giga port just to name a few
mi virtual dj said not enough chanels with the asio4all soundcard
what can i do??
i have virtual dj 7Pro
