this is the first time i use a mixxing software and i recently purchased the numark dmc2 and the c3 usb mixer and i want to know how do i install the equipment with virtual dj.
note: i bought it the equipment used so i dont have manuals thanks.
geposted Fri 17 Apr 09 @ 2:06 pm
Hi there, you should be able to download the manuals for the internet i would have thought:
Virtual DJ Manual: https://virtualdj.com/wiki/PDFManuals.html
DMC2: http://www.numark.com/content1348.html
http://www.numark.com/content60105.html
C3: http://www.numark.com/content206123.html
If you still have a problem please be more specific as to what works and what doesnt and we shall try and help you fix it.
geposted Fri 17 Apr 09 @ 2:21 pm
thanks alot ill check out the links
geposted Fri 17 Apr 09 @ 6:00 pm
