Excuse my ignorance, but I am totally new to all of this. I just wanted to confirm that the mic plugin wont work with a usb mic.
Ta
Ta
geposted Mon 14 Mar 05 @ 2:14 pm
It's possible. Never try it.
The author of this plugin is Kaleo
geposted Mon 14 Mar 05 @ 3:10 pm
Anyone? HELP>
geposted Tue 15 Mar 05 @ 9:45 am
Never tried ... Maybe someone else ?
Did you check your config ?
geposted Tue 15 Mar 05 @ 10:23 am
Checked config, ok. Anyone else?? Its not a trick question.
geposted Wed 16 Mar 05 @ 1:45 am
hello where can i download the a mic plugin i can't find it
geposted Sun 29 Aug 10 @ 11:43 am
i am with the same problem
geposted Tue 31 Aug 10 @ 3:52 am
If you change the category tab to "Older" on the Download section's browser you will see the plugins made for the previous versions of VDJ.keep in mind this might or might NOT work.Downloads of plugins are for Licenced users only I'm afraid..
geposted Wed 01 Sep 10 @ 8:44 pm
