Hello!
Can someone here help me:
https://virtualdj.com/forums/108247/General_Discussion/Problem_with_Cue_LE__DMC2___CM200USB.html
Thanks in advance!
/Fredde
Thanks in advance!
/Fredde
geposted Wed 29 Apr 09 @ 3:30 am
Hei Fredde,
Are you using XP or Vista? In Xp vdj recognizes the cm200usb as a sound card, so you can select it from the Output selection menu. So instead of selecting external mixer you would select the cmusb, although it appears with a different name, but you can see an USB mixer picture.
In vista you have to select external mixer.
Also, windows should recognized two sound cards (usb audio codec 1) and (usb audio codec 2). I see you only have one sound card beeing recognized, so check in the back on the mixer and see you have selected ch3 and ch4 for each usb output.
Hope it helps.
Hope it helps.
geposted Wed 29 Apr 09 @ 4:10 am
Hi !
Thanks a lot, that helped me by choosing the USB mixer picture :-)
Now im going to mix music and videos until i die :-)
Now im just have to learn more ways to mix then just normal beatmix, but thats another thing :-)
I just want to thank all people in this forum that have helped me, i love you guys................and girls :-)
Thanks!
/Fredde
Thanks!
/Fredde
geposted Wed 29 Apr 09 @ 12:20 pm
Sorry Freddem, I should have asked if you had XP or Vista, I was going off of the Vista config, sorry! Obviously now you see the numbered USB codecs I was talking about. Great! I'm glad you got it sorted
RuDe
RuDe
geposted Wed 29 Apr 09 @ 1:52 pm
