Gang -
I have 5.2.1 on a laptop. 1gb of memory and SATA HD. I am thinking it's the wimpier core duo (Gateway).
Anyhow, it takes almost 5 min to load. Once launched, it is quite frisky.
Thoughts?
Thoughts?
geposted Tue 12 May 09 @ 9:33 pm
This might be a clue... it 'hangs up' on loading database. The database is 150mb in size.
However, subsequent launching of VDJ is quite snappy - until it gets rebooted.
Advice?
Advice?
geposted Wed 13 May 09 @ 7:39 am
Yes, make your database smaller, or on a faster drive - I'm going to assume this is an external drive?
This user had the same problem (with a much smaller database) which turned out to be a driver problem on his PC:
https://virtualdj.com/forums/103228/Wishes_and_new_features/fast_load_with_out_preloading_database__SOLVED_.html
geposted Wed 13 May 09 @ 9:25 am
Thanks gang... FIX was the magic key. Went from 150mb to 26mb. Now it loads more better. :)
geposted Wed 13 May 09 @ 4:58 pm
