dOES ANYONE HAVE A CDJ 400 AND CANNOT USE THE JOG WHEEL EFFECTIVELY, BUT IT SEEMS TO ME THAT WITH NATIVE SUPPORT, IT SHOULD WORK CORRECTLY. CAN SOMONE /ANYONE HELP ME I NEED THE JOG WHELL TO OPERATE NORMALLY LIKE IN CD MODE( BY THE WAY I DOWNLOADED A MIDI MAPPER FROM A PIONEER FORUM AND WHILE USIN THE JOG WHEEL WITH THE MAPPER VDJ WORKED AS IF WHY CANT SOMONE MAKE A MAPPER THAT THE JOG WHEEL WORKS JUST LIKE IT DOES WHEN USUING A CD-- WORKS
ALSO IT WOULD BE NICE TO USE THE SYNC MAPPED BUTTON TO SWITCH FROM EFFECTS TO HOT CUES
DJ JAMM
DJ JAMM
geposted Mon 18 May 09 @ 3:15 am
Firstly, please turn off your caps lock ;)
Secondly, you can map MIDI yourself easily. If you want a DLL file creating, you would have to code it or ask someone to do it for you. That person would really need a CDJ400 to test on.
geposted Mon 18 May 09 @ 7:30 am
