I currently have the "Cut" sound effect plug-in assigned as a keyboard shortcut to the "C" key on my Macbook keyboard. The problem is whenever I restart VirtualVinyl the keyboard shortcut changes from "effect_activate(Cut)" to "effect_activate (temporary)". So what this means is whenever I hit the "C" key, instead of activating the "Cut" sound effect, it activates whatever the last effect I used was. This only happens with the "Cut" sound effect, not the others. The only temporary solution I've found is every time I open VV I have to go into the shortcuts menu and change the "C" key from "effect_activate(Cut)" back to "effect_activate (temporary)".
And yes, I have enabled all the permissions for every folder in VV.
Any ideas guys, or is this just a glitch with this particular sound effect plug-in?
geposted Fri 22 May 09 @ 5:00 pm
I have the same problem with the Cut plugin in PCDJ VJ
geposted Mon 25 May 09 @ 1:18 pm
