I have some problems (loop doesn't clip to the right looppoint) which (according to the helpdesk) should be fixed with an update to 5.2.2
When I take a look in the preferences of VDJ, It says I have version 5.2
When I click the update button it says 'your software is already updated'
The autoupdater doesn't download anything or tells there is an update available.
The loop error still excists, so before writing VDJ off, I want to make sure which version I do have right now. How van I check (and if it really is 5.2.. how van I update?)
geposted Sat 23 May 09 @ 5:01 am
see which version is available for you to download here: https://virtualdj.com/download/updates.html
I beleive 5.2.2 is the lastest version for LE. (but i could be wrong)
geposted Sat 23 May 09 @ 5:08 pm
Yes V5.2.2LE for rmx is the latest.
geposted Sat 23 May 09 @ 5:17 pm
