Forum: Old versions
Topic: Feedback Issues?
Does anyone have any feedback issues with their DJ system using a pc? how about using a mac?
geposted Sun 24 May 09 @ 11:44 am
Hi i am having feedback issues. My external soundcard and headphone out both give off a digital noise from the pc. it reacts worse everytime i move my mouse etc.
can anyone help i have my first gig using pc on friday!!
thanks
Have you guys checked out the PC optimzation guides in the the sticky "top" protion of this forum area? https://virtualdj.com/forums/64699/PC_Version_Technical_Support/SELECTED_SOFTWARE_GUIDES.html
My system runs great and has for a long time now. Just like you, it took some tweaking to get it perfect in the beginning though. The best place to look is always in the stickies at the top of each forum room. Those are like the "most frequently seen issues" which is why they have stars.
Because you are both not registered, I have no idea what version you are running though. When you do you can get more specifc support on your issues.
When I first set up my mobile DJing equipment I had the same issue. Very noticable when doing karaoke. I fixed the problem with a Ground Loop issolator from Radio Shack, about $18. Also an external sound card can help if you are picking up noise from your hard drive being too close to sound card or not sheilded properly (from what my computer tech told me).
I also fixed this problem using a simple three prong plug adaptor that turns the three prong computer power supply plug into two. They look like this: http://www.bhphotovideo.com/c/product/205124-REG/General_Brand_03408_3_to_2_Prong.html
Howard you are the man I just bought about 2000 dollars worth of Peavey Equipment and I had very very bad feed back. I was about to buy a new laptop or do something quick because I have a very big gig coming this Saturday this saved me a lot of money thanks so much for the input thank you thank you and thank you again.........(- _-)
