Forum: Old versions
Topic: Virtual DJ6 and Numark NS7 (genelar topic) - Page: 1
So what about the NS7 ! We are waiting for more informations about the maping of this controler ! it is not on the 40 premapped controler list
Now , has the NS7 been tested on vdj6 or not ? please give us information !
I already have the ns7 and on vdj I can map buttons and leds and what about the platters please . when i turn the plater it crash and close vdj6
thanks for the answer .
geposted Mon 01 Jun 09 @ 1:56 am
I have the NS7 and I think ITCH is ok. I was a big fan of VIrtual DJ, But for what I do for a living I could not afford BUGS and Crashes and that I was the situation when I was a VDJ i5.2 user. I would love to use VDJ again with my NSy which I love. I would love to use the Hercules with VDJ for the coctail hour of weedings, sweet 16ths, and use the NS7 for the reception and heavy duty events. So that being said, it will be nice to be able to use the NS7 and the hercules with one DJ Software VDJ6. So please let us know when will VDJ work with The NS7.
Thanks,
FrankTHEDJ
V6 is 14bit which means that NS7 functionality isfully capable.. as opposed to 5.2.1
as to why it is not native... only VDJ can answer that
however chances are even if it is not native.. someone out there is working on a mapper
patience is a virtue..... expectations are on this one
Mapper will come ;) someone will make that pretty soon i bet ;)
Well I am about to make a 1300US investment on this hardware, reason for not purchasing earlier was the pending release of vdj v6.
However the current responses from "technical support" are not encouraging as I thought the Ns7 would have been native in v6.
I do professional video mixing therefore I not only need a solid solution, but something which is also feasible to my budget and the Ns7 will full that outstanding void for a Pro-Controller.
Video mixing is quite dissimilar from just straight audio and 2 variables have to be considered
-Audio
-Video
If I'm to purchase regular turntables and use timecode or midi, this will get expensive very fast, therefore I'm imploring on the Dev Team to have a competent midi support for this particular controller and please always bear in mind the VDJ end users and not the "inter-business relationship" between entities.
you forgot to mention the cost of importing the product to you.. stream..... that will cost you another bundle... especially with the tax increases.. as well as shipping by the courier
There are so many controllers made native in V6 - but most still considered toys
So many professional decks giving issues
Seems that somewhere VDJ and Numark has issues -
makes no sense however for backs to be turned on each other
bottom line = VDJ - great software and Numark (VCI-300 and NS7) great hardware - solution to many
So regardless of the assumed (volatile relationship) a marrying of both products - is required for VDJ to stay on top
VDJ - must get the mappers right and flawlessly for the NS7 - whether it is natively supported or not. I call on the powers that be
the programmers for mappers... this can only be advantageous
Like I said in the other thread, something seems amiss in the VDJ/Numark relationship. The NS7 would have been native if everything was copacetic between the two entities. Seems like they’ve jumped on the Serato bandwagon and left us VDJ users in the dust?
I will try to finish my work on a NS7 mapper at Wednesday. I personaly do not own a controller so i am not able to get the MIDI notes i need for it. If someone can take a log of the last 4 buttons and the jogs i could try to finish it earlier.
I just need 4 the midi notes of the 4 buttons on the front and some logging of the jogs.
http://www.midiox.com/moxdown.htm
Just install this little tool, start it (without VDJ running) and then select the midi port:
- 'Options' - 'Midi Device' - 'Input device'
Now switch the following buttons from left to right and back (each one after the other):
Fader start A
Motor torque
XFader Reverse
Fader start B
in the Monitor INPUT Window there should be some midi commands. Please copy them by right click and 'Copy all' and post them here.
Also i need some log of the jogs:
right mouse button in the INPUT Window - 'Clear input'. Then turn the LEFT jog CLOCKWISE about 5 times SLOWLY.
Copy the log, post it and do the same REVERSE-CLOCK, also post it. Do the same for the right jog. Please write text before the log - just i know which jog you turn and which direction. (turn the wheels whith holding the vinyl)
The same thing with the jogs but NOT touching the vinyls.
At least i need the information about 'Motor off', 'Start time', 'Stop time' - i think they are no midi, but try if there are any MIDI Signals from that faders.
When everything works we could get the LED information - but i think this should be the last thing to work on.
Greets, Heiko
Fader start A
Motor torque
XFader Reverse
Fader start B
Greets, Heiko
I have an NS7 and will try to get this midi info for you :) As I want to actually use my NS7 because ITCH sucks
Fader start A
Motor torque
XFader Reverse
Fader start B
Greets, Heiko
Here is the info you requested in the exact order on:
Fader start A
Motor torque
XFader Reverse
Fader start B
TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT
Opened MIDI Input
00002F5F 3 -- 90 02 7F 1 D -1 Note On
0000308B 3 -- B0 00 39 1 --- CC: Bank MSB
0000308B 3 -- E0 69 06 1 --- Pitch Bend
000037AC 3 -- 90 02 00 1 D -1 Note Off
00004914 3 -- 90 05 7F 1 F -1 Note On
00004FCA 3 -- 90 05 00 1 F -1 Note Off
00006674 3 -- 90 04 7F 1 E -1 Note On
00006F43 3 -- 90 04 00 1 E -1 Note Off
00007F8A 3 -- 90 03 7F 1 Eb-1 Note On
00008744 3 -- 90 03 00 1 Eb-1 Note Off
I'm putting these as text files as they are too long to post here and get truncated when posted.
MIDI-OX LOGS
LEFT JOG WHEEL CLOCKWISE (Touching Vinyl)
http://mybishop.net/ns7midilogs/Left%20Jog%20Wheel%20Clockwise.txt
LEFT JOG WHEEL COUNTERCLOCKWISE (Touching Vinyl)
http://mybishop.net/ns7midilogs/Left%20Jog%20Wheel%20CounterClockwise%20(Touching%20Vinyl).txt
LEFT JOG WHEEL CLOCKWISE (NOT Touching Vinyl)
http://mybishop.net/ns7midilogs/Left%20Jog%20Wheel%20Clockwise%20(NOT%20Touching%20Vinyl).txt
LEFT JOG WHEEL COUNTERCLOCKWISE (NOT Touching Vinyl)
http://mybishop.net/ns7midilogs/Left%20Jog%20Wheel%20CounterClockwise%20(NOT%20Touching%20Vinyl).txt
Motor Off - LEFT DECK
001C97C8 3 -- 90 21 7F 1 A 1 Note On
001C981E 3 -- 90 21 00 1 A 1 Note Off
Stop Time - LEFT DECK
http://mybishop.net/ns7midilogs/Stop%20Time%20-%20Left%20Deck.txt
Start Time - LEFT DECK
http://mybishop.net/ns7midilogs/Start%20Time%20-%20Left%20Deck.txt
Strip Search - LEFT DECK
http://mybishop.net/ns7midilogs/Strip%20Search%20%20-%20Left%20Deck.txt
BLEEP - Left Deck
0004DB6F 3 -- 90 1C 7F 1 E 1 Note On
0004DC42 3 -- 90 1C 00 1 E 1 Note Off
Reverse - LEFT DECK
00066874 3 -- 90 1D 7F 1 F 1 Note On
000689D6 3 -- 90 1D 00 1 F 1 Note Off
Loop Control - Left Deck (ON/OFF Button)
0009DBA5 3 -- 90 24 7F 1 C 2 Note On
0009DC30 3 -- 90 24 00 1 C 2 Note Off
Loop Control - Left Deck (1/2 X Button)
000BB3D1 3 -- 90 22 7F 1 Bb 1 Note On
000BB42F 3 -- 90 22 00 1 Bb 1 Note Off
Loop Control - Left Deck (2 X Button)
000D04E4 3 -- 90 23 7F 1 B 1 Note On
000D0539 3 -- 90 23 00 1 B 1 Note Off
Loop Control - Left Deck (Shift Back Button)
000DABB6 3 -- 90 25 7F 1 C# 2 Note On
000DAC22 3 -- 90 25 00 1 C# 2 Note Off
Loop Control - Left Deck (Shift Forward Button)
000EA611 3 -- 90 26 7F 1 D 2 Note On
000EA653 3 -- 90 26 00 1 D 2 Note Off
MIDITRACE LOGS (DJCel requested these)
Seems your post got cut of... too long maybe
Could you save it to a word document, and upload it somewhere?
for example here:
http://www.speedyshare.com/
ah you saw ;)
dj-in-norway wrote :
ah you saw ;)
yup :)
I put forward the notion to make this thread a "Sticky", lets make this a collaborative effort between users and Atomix Dev Team, PLEASE !!!
MIDI-OX LOGS - CONTINUED For some reason it stopped letting me modify my previous post
Manual Mode / Auto Loop Button - LEFT DECK
001D3F7C 3 -- 90 27 7F 1 Eb 2 Note On
001D3FD9 3 -- 90 27 00 1 Eb 2 Note Off
In (Begin Loop) / 1 Beat AutoLoop Button - LEFT DECK
001DBB14 3 -- 90 28 7F 1 E 2 Note On
001DBB5B 3 -- 90 28 00 1 E 2 Note Off
Out (End Loop) / 2 Beat AutoLoop Button - LEFT DECK
001DF14E 3 -- 90 29 7F 1 F 2 Note On
001DF19B 3 -- 90 29 00 1 F 2 Note Off
Select / 4 Beat AutoLoop Button - LEFT DECK
001E2C00 3 -- 90 2A 7F 1 F# 2 Note On
001E2C35 3 -- 90 2A 00 1 F# 2 Note Off
Reloop / 8 Beat AutoLoop Button - LEFT DECK
001E74AC 3 -- 90 2B 7F 1 G 2 Note On
001E74FF 3 -- 90 2B 00 1 G 2 Note Off
TAP BPM Button - LEFT DECK
00224C88 3 -- 90 1E 7F 1 F# 1 Note On
00224CC9 3 -- 90 1E 00 1 F# 1 Note Off
Track BACK Button (Underneath Strip Search) - LEFT DECK
0021E118 3 -- 90 1F 7F 1 G 1 Note On
0021E158 3 -- 90 1F 00 1 G 1 Note Off
Track Forward Button (Underneath Strip Search) - LEFT DECK
00220EEB 3 -- 90 20 7F 1 G# 1 Note On
00220F32 3 -- 90 20 00 1 G# 1 Note Off
DELETE Cue Button - LEFT DECK
0023EA61 3 -- 90 12 7F 1 F# 0 Note On
0023EADE 3 -- 90 12 00 1 F# 0 Note Off
Hot Cue 1 - LEFT DECK
00267D5B 3 -- 90 13 7F 1 G 0 Note On
00267D99 3 -- 90 13 00 1 G 0 Note Off
Hot Cue 2 - LEFT DECK
0026BE78 3 -- 90 14 7F 1 G# 0 Note On
0026BEB0 3 -- 90 14 00 1 G# 0 Note Off
Hot Cue 3 - LEFT DECK
0026E721 3 -- 90 15 7F 1 A 0 Note On
0026E75E 3 -- 90 15 00 1 A 0 Note Off
Hot Cue 4 - LEFT DECK
00272219 3 -- 90 16 7F 1 Bb 0 Note On
00272254 3 -- 90 16 00 1 Bb 0 Note Off
Hot Cue 5 - LEFT DECK
00275547 3 -- 90 17 7F 1 B 0 Note On
0027559F 3 -- 90 17 00 1 B 0 Note Off
SYNC Button - LEFT DECK
002793A9 3 -- 90 0F 7F 1 Eb 0 Note On
0027940E 3 -- 90 0F 00 1 Eb 0 Note Off
0027B8DD 3 -- 90 10 7F 1 E 0 Note On
0027B91D 3 -- 90 10 00 1 E 0 Note Off
Play/Pause Button - LEFT DECK
0027EFBD 3 -- 90 11 7F 1 F 0 Note On
0027F017 3 -- 90 11 00 1 F 0 Note Off
Pitch Range Button - LEFT DECK
002C437F 3 -- 90 1A 7F 1 D 1 Note On
002C5147 3 -- 90 1A 00 1 D 1 Note Off
Keylock Button - LEFT DECK
002C852B 3 -- 90 1B 7F 1 Eb 1 Note On
002C8565 3 -- 90 1B 00 1 Eb 1 Note Off
PitchBend - (Minus) - Left DECK
002CC424 3 -- 90 18 7F 1 C 1 Note On
002CC477 3 -- 90 18 00 1 C 1 Note Off
PitchBend + (Plus) - Left DECK
002D0052 3 -- 90 19 7F 1 C# 1 Note On
002D0097 3 -- 90 19 00 1 C# 1 Note Off
Pitch Slider (From 0 to Negative 0) - Left Deck
http://mybishop.net/ns7midilogs/Pitch%20Slider%20(From%200%20to%20Negative%200)%20%20-%20Left%20Deck.txt
Pitch Slider (From 0 to Positive 0) - Left Deck
http://mybishop.net/ns7midilogs/Pitch%20Slider%20(From%200%20to%20Positive%200)%20%20-%20Left%20Deck.txt
Meter Mode - CENTER MIXER (LEFT is CH1-CH2 / Flipped right is MASTER)
003422A4 3 -- 90 01 00 1 C#-1 Note Off
00342925 3 -- 90 01 7F 1 C#-1 Note On
Headphone Mode - CENTER MIXER (LEFT is CH1-CH2 / Flipped right is MASTER)
00371F31 3 -- 90 00 00 1 C -1 Note Off
00372442 3 -- 90 00 7F 1 C -1 Note On
Headphone CUE Crossfade from Center to Left CH1 then back to CENTER - MIXER BOARD
http://mybishop.net/ns7midilogs/Headphone%20CUE%20Crossfade%20from%20Center%20to%20Left%20CH1%20then%20back%20to%20CENTER%20-%20MIXER%20BOARD.txt
Headphone CUE Crossfade from Center to RIGHT CH2 then back to CENTER - MIXER BOARD
http://mybishop.net/ns7midilogs/Headphone%20CUE%20Crossfade%20from%20Center%20to%20RIGHT%20CH2%20then%20back%20to%20CENTER%20-%20MIXER%20BOARD.txt
Well that should get things rolling the left deck and some of the mixer board. I will be back later to do the rest. Also I will be posting all the MidiTrace logs as well. :)
MIDI-OX LOGS - CONTINUED 2 For some reason it stopped letting me modify my previous post again
Xfader Contour Knob - Mixer Board
http://mybishop.net/ns7midilogs/Xfader%20Contour%20Knob%20-%20Mixer%20Board.txt
Back button on VIEW (Jumps between menus ex: Files on left, songs on right. Like a menu taber Horizontally) - Mixer Board TOP
00628C1C 3 -- 90 06 7F 1 F#-1 Note On
00628C80 3 -- 90 06 00 1 F#-1 Note Off
FWD button on VIEW (Jumps between menus ex: Files on left, songs on right. Like a menu taber Horizontally) - Mixer Board TOP
00653ECC 3 -- 90 07 7F 1 G -1 Note On
00653F12 3 -- 90 07 00 1 G -1 Note Off
Scroll Knob has 2 functions:
1 You can jump around the crates and files windows as you see fit and scroll around with the large knob
2 and select by pressing it in
Scroll Knob [Function 1 of 2 - Turning Clockwise] (Scrolls thru selected menus ex: Songs in a folder, songs searched for etc...) - Mixer Board TOP
0068B8A9 3 -- B0 44 01 1 --- Control Change
0068B9CD 3 -- B0 44 01 1 --- Control Change
0068BAEE 3 -- B0 44 01 1 --- Control Change
0068BC0A 3 -- B0 44 01 1 --- Control Change
0068BCE3 3 -- B0 44 01 1 --- Control Change
0068BDEB 3 -- B0 44 01 1 --- Control Change
0068BED4 3 -- B0 44 01 1 --- Control Change
0068BFA0 3 -- B0 44 01 1 --- Control Change
0068C0D3 3 -- B0 44 01 1 --- Control Change
0068C1DB 3 -- B0 44 01 1 --- Control Change
0068C2D3 3 -- B0 44 01 1 --- Control Change
0068C388 3 -- B0 44 01 1 --- Control Change
0068C4F0 3 -- B0 44 01 1 --- Control Change
0068C618 3 -- B0 44 01 1 --- Control Change
0068C782 3 -- B0 44 01 1 --- Control Change
0068C899 3 -- B0 44 01 1 --- Control Change
0068CCE1 3 -- B0 44 01 1 --- Control Change
0068CE73 3 -- B0 44 01 1 --- Control Change
0068CFB8 3 -- B0 44 01 1 --- Control Change
0068D103 3 -- B0 44 01 1 --- Control Change
0068D257 3 -- B0 44 01 1 --- Control Change
0068D368 3 -- B0 44 01 1 --- Control Change
0068D876 3 -- B0 44 01 1 --- Control Change
0068D8FE 3 -- B0 44 01 1 --- Control Change
0068D946 3 -- B0 44 01 1 --- Control Change
0068D98A 3 -- B0 44 01 1 --- Control Change
0068D9EA 3 -- B0 44 01 1 --- Control Change
0068DA41 3 -- B0 44 01 1 --- Control Change
0068DA91 3 -- B0 44 01 1 --- Control Change
0068DD3F 3 -- B0 44 01 1 --- Control Change
0068DDBD 3 -- B0 44 01 1 --- Control Change
Scroll Knob [Function 1 of 2 - Turning Counter Clockwise] (Scrolls thru selected menus ex: Songs in a folder, songs searched for etc...) - Mixer Board TOP
00697BD1 3 -- B0 44 7F 1 --- Control Change
00697D9C 3 -- B0 44 7F 1 --- Control Change
00697EE2 3 -- B0 44 7F 1 --- Control Change
00697FF5 3 -- B0 44 7F 1 --- Control Change
00698131 3 -- B0 44 7F 1 --- Control Change
0069823A 3 -- B0 44 7F 1 --- Control Change
006983C6 3 -- B0 44 7F 1 --- Control Change
00698474 3 -- B0 44 7F 1 --- Control Change
00698557 3 -- B0 44 7F 1 --- Control Change
006985F3 3 -- B0 44 7F 1 --- Control Change
00698750 3 -- B0 44 7F 1 --- Control Change
00698820 3 -- B0 44 7F 1 --- Control Change
00698887 3 -- B0 44 7F 1 --- Control Change
006988F7 3 -- B0 44 7F 1 --- Control Change
00698CC3 3 -- B0 44 7F 1 --- Control Change
00698D2B 3 -- B0 44 7F 1 --- Control Change
00698D97 3 -- B0 44 7F 1 --- Control Change
00698DF6 3 -- B0 44 7F 1 --- Control Change
00698E7A 3 -- B0 44 7F 1 --- Control Change
00698EF0 3 -- B0 44 7F 1 --- Control Change
00698F3F 3 -- B0 44 7F 1 --- Control Change
00698F90 3 -- B0 44 7F 1 --- Control Change
00698FD4 3 -- B0 44 7F 1 --- Control Change
0069900D 3 -- B0 44 7F 1 --- Control Change
0069908F 3 -- B0 44 7F 1 --- Control Change
006990E9 3 -- B0 44 7F 1 --- Control Change
00699117 3 -- B0 44 7F 1 --- Control Change
00699149 3 -- B0 44 7F 1 --- Control Change
00699478 3 -- B0 44 7F 1 --- Control Change
006994BB 3 -- B0 44 7F 1 --- Control Change
006994F3 3 -- B0 44 7F 1 --- Control Change
0069952D 3 -- B0 44 7F 1 --- Control Change
00699575 3 -- B0 44 7F 1 --- Control Change
006995B9 3 -- B0 44 7F 1 --- Control Change
00699601 3 -- B0 44 7F 1 --- Control Change
0069965F 3 -- B0 44 7F 1 --- Control Change
00699697 3 -- B0 44 7F 1 --- Control Change
006996D9 3 -- B0 44 7F 1 --- Control Change
00699730 3 -- B0 44 7F 1 --- Control Change
00699788 3 -- B0 44 7F 1 --- Control Change
006997BC 3 -- B0 44 7F 1 --- Control Change
00699B0D 3 -- B0 44 7F 1 --- Control Change
00699B37 3 -- B0 44 7F 1 --- Control Change
00699B77 3 -- B0 44 7F 1 --- Control Change
00699BA6 3 -- B0 44 7F 1 --- Control Change
00699BC5 3 -- B0 44 7F 1 --- Control Change
00699BDE 3 -- B0 44 7F 1 --- Control Change
00699BF8 3 -- B0 44 7F 1 --- Control Change
00699C10 3 -- B0 44 7F 1 --- Control Change
00699C2B 3 -- B0 44 7F 1 --- Control Change
00699C52 3 -- B0 44 7F 1 --- Control Change
00699C78 3 -- B0 44 7F 1 --- Control Change
00699CB2 3 -- B0 44 7F 1 --- Control Change
00699FB6 3 -- B0 44 7F 1 --- Control Change
00699FE8 3 -- B0 44 7F 1 --- Control Change
0069A021 3 -- B0 44 7F 1 --- Control Change
0069A057 3 -- B0 44 7F 1 --- Control Change
0069A093 3 -- B0 44 7F 1 --- Control Change
0069A0D7 3 -- B0 44 7F 1 --- Control Change
0069A96F 3 -- B0 44 7F 1 --- Control Change
0069A99B 3 -- B0 44 7F 1 --- Control Change
0069A9C3 3 -- B0 44 7F 1 --- Control Change
0069A9E3 3 -- B0 44 7F 1 --- Control Change
0069A9F9 3 -- B0 44 7F 1 --- Control Change
0069AA13 3 -- B0 44 7F 1 --- Control Change
0069AA25 3 -- B0 44 7F 1 --- Control Change
0069AA39 3 -- B0 44 7F 1 --- Control Change
0069AA4F 3 -- B0 44 7F 1 --- Control Change
Scroll Knob [Function 2 of 2 - Pushing scroll knob in like a button it clicks in and out] (Jumps between menus like FWD button on view) - Mixer Board TOP
006EB9D1 3 -- 90 08 7F 1 G#-1 Note On
006EBA4B 3 -- 90 08 00 1 G#-1 Note Off
Crates Button on View (Navigates through the browser tree & favorites) - Mixer Board Top
007265D7 3 -- 90 0B 7F 1 B -1 Note On
00726651 3 -- 90 0B 00 1 B -1 Note Off
Prepare Button on View (Makes a Temp selection in a playlist and removes it once played so in Virtual I guess it would just become a RED File) - MIXER BOARD TOP
0089E918 3 -- 90 09 7F 1 A -1 Note On
0089E970 3 -- 90 09 00 1 A -1 Note Off
Load Prepare Button (will load the selected track into the preview deck) - MIXER BOARD TOP
008A2337 3 -- 90 0D 7F 1 C# 0 Note On
008A23BA 3 -- 90 0D 00 1 C# 0 Note Off
Files Button (switches to browser view only - ex goes to files menu, the directory way like on the left side of Virtual) - MIXER BOARD TOP
008AC04F 3 -- 90 0A 7F 1 Bb-1 Note On
008AC0A9 3 -- 90 0A 00 1 Bb-1 Note Off
LOAD A Button (Loads highlighted song to left deck) - Mixer Board TOP
008BE6B3 3 -- 90 0C 7F 1 C 0 Note On
008BE6F9 3 -- 90 0C 00 1 C 0 Note Off
LOAD B Button (Loads highlighted song to Right deck) - Mixer Board TOP
008C330F 3 -- 90 0E 7F 1 D 0 Note On
008C335F 3 -- 90 0E 00 1 D 0 Note Off
Gain Knob CH1 (Min To Max) - Mixer Board
http://mybishop.net/ns7midilogs/Gain%20Knob%20CH1%20(Min%20To%20Max)%20-%20Mixer%20Board.txt
Gain Knob CH1 (Max To Min) - Mixer Board
http://mybishop.net/ns7midilogs/Gain%20Knob%20CH1%20(Max%20To%20Min)%20-%20Mixer%20Board.txt
Treble Knob CH1 (Min To Max) - Mixer Board
http://mybishop.net/ns7midilogs/Treble%20Knob%20CH1%20(Min%20To%20Max)%20-%20Mixer%20Board.txt
Treble Knob CH1 (Max To Min) - Mixer Board
http://mybishop.net/ns7midilogs/Treble%20Knob%20CH1%20(Max%20To%20Min)%20-%20Mixer%20Board.txt
MID Knob CH1 (Min To Max) - Mixer Board
http://mybishop.net/ns7midilogs/MID%20Knob%20CH1%20(Min%20To%20Max)%20-%20Mixer%20Board.txt
MID Knob CH1 (Max To Min) - Mixer Board
Bass Knob CH1 (Min To Max) - Mixer Board
http://mybishop.net/ns7midilogs/Bass%20Knob%20CH1%20(Min%20To%20Max)%20-%20Mixer%20Board.txt
Bass Knob CH1 (Max To Min) - Mixer Board
http://mybishop.net/ns7midilogs/Bass%20Knob%20CH1%20(Max%20To%20Min)%20-%20Mixer%20Board.txt
Master Volume Knob (Min To Max) - Mixer Board
http://mybishop.net/ns7midilogs/Master%20Volume%20Knob%20(Min%20To%20Max)%20-%20Mixer%20Board.txt
Master Volume Knob (Max To Min) - Mixer Board
http://mybishop.net/ns7midilogs/MID%20Knob%20CH1%20(Max%20To%20Min)%20-%20Mixer%20Board.txt
MIDI-OX LOGS - CONTINUED 3 For some reason once again it stopped letting me modify my previous post
Booth Knob (For Controls Booth Monitor Output on back) (Min to Max)
http://mybishop.net/ns7midilogs/Booth%20Knob%20(For%20Controls%20Booth%20Monitor%20Output%20on%20back)%20(Min%20to%20Max).txt
Booth Knob (For Controls Booth Monitor Output on back) (Max to Min)
http://mybishop.net/ns7midilogs/Booth%20Knob%20(For%20Controls%20Booth%20Monitor%20Output%20on%20back)%20(Max%20to%20Min).txt
Gain Knob CH2 (Min To Max) - Mixer Board
http://mybishop.net/ns7midilogs/Gain%20Knob%20CH2%20(Min%20To%20Max)%20-%20Mixer%20Board.txt
Gain Knob CH2 (Max To Min) - Mixer Board
http://mybishop.net/ns7midilogs/Gain%20Knob%20CH2%20(Max%20To%20Min)%20-%20Mixer%20Board.txt
Treble Knob CH2 (Min To Max) - Mixer Board
http://mybishop.net/ns7midilogs/Treble%20Knob%20CH2%20(Min%20To%20Max)%20-%20Mixer%20Board.txt
Treble Knob CH2 (Max To Min) - Mixer Board
http://mybishop.net/ns7midilogs/Treble%20Knob%20CH2%20(Max%20To%20Min)%20-%20Mixer%20Board.txt
MID Knob CH2 (Min To Max) - Mixer Board
http://mybishop.net/ns7midilogs/MID%20Knob%20CH2%20(Min%20To%20Max)%20-%20Mixer%20Board.txt
MID Knob CH2 (Max To Min) - Mixer Board
http://mybishop.net/ns7midilogs/MID%20Knob%20CH2%20(Max%20To%20Min)%20-%20Mixer%20Board.txt
Bass Knob CH2 (Min To Max) - Mixer Board
http://mybishop.net/ns7midilogs/Bass%20Knob%20CH2%20(Min%20To%20Max)%20-%20Mixer%20Board.txt
Bass Knob CH2 (Max To Min) - Mixer Board
http://mybishop.net/ns7midilogs/Bass%20Knob%20CH2%20(Max%20To%20Min)%20-%20Mixer%20Board.txt
Channel 1 Volume Fader (Min to Max) - Mixer Board
http://mybishop.net/ns7midilogs/Channel%201%20Volume%20Fader%20(Min%20to%20Max)%20-%20Mixer%20Board.txt
Channel 1 Volume Fader (Max to Min) - Mixer Board
http://mybishop.net/ns7midilogs/Channel%201%20Volume%20Fader%20(Max%20to%20Min)%20-%20Mixer%20Board.txt
Channel 2 Volume Fader (Min to Max) - Mixer Board
http://mybishop.net/ns7midilogs/Channel%202%20Volume%20Fader%20(Min%20to%20Max)%20-%20Mixer%20Board.txt
Channel 2 Volume Fader (Max to Min) - Mixer Board
http://mybishop.net/ns7midilogs/Channel%202%20Volume%20Fader%20(Max%20to%20Min)%20-%20Mixer%20Board.txt
Crossfader (From Left to Right) - Mixer Board
http://mybishop.net/ns7midilogs/Crossfader%20(From%20Left%20to%20Right)%20-%20Mixer%20Board.txt
Crossfader (From Right to Left) - Mixer Board
http://mybishop.net/ns7midilogs/Crossfader%20(From%20Right%20to%20Left)%20-%20Mixer%20Board.txt
MIDI-OX LOGS - CONTINUED 4
RIGHT JOG WHEEL CLOCKWISE (Touching Vinyl)
http://mybishop.net/ns7midilogs/RIGHT%20JOG%20WHEEL%20CLOCKWISE%20(Touching%20Vinyl).txt
RIGHT JOG WHEEL COUNTERCLOCKWISE (Touching Vinyl)
http://mybishop.net/ns7midilogs/RIGHT%20JOG%20WHEEL%20COUNTERCLOCKWISE%20(Touching%20Vinyl).txt
RIGHT JOG WHEEL CLOCKWISE (NOT Touching Vinyl)
http://mybishop.net/ns7midilogs/RIGHT%20JOG%20WHEEL%20CLOCKWISE%20(NOT%20Touching%20Vinyl).txt
RIGHT JOG WHEEL COUNTERCLOCKWISE (NOT Touching Vinyl)
http://mybishop.net/ns7midilogs/RIGHT%20JOG%20WHEEL%20COUNTERCLOCKWISE%20(NOT%20Touching%20Vinyl).txt
Motor Off - RIGHT DECK
00D590B5 3 -- 90 42 7F 1 F# 4 Note On
00D59143 3 -- 90 42 00 1 F# 4 Note Off
Stop Time - RIGHT DECK
http://mybishop.net/ns7midilogs/Stop%20Time%20-%20RIGHT%20DECK.txt
Start Time - RIGHT DECK
http://mybishop.net/ns7midilogs/Start%20Time%20-%20RIGHT%20DECK.txt
Strip Search - RIGHT DECK
http://mybishop.net/ns7midilogs/Strip%20Search%20-%20RIGHT%20DECK.txt
BLEEP - RIGHT DECK
00D6171F 3 -- 90 3D 7F 1 C# 4 Note On
00D61824 3 -- 90 3D 00 1 C# 4 Note Off
Reverse - RIGHT DECK
00D656CB 3 -- 90 3E 7F 1 D 4 Note On
00D6633E 3 -- 90 3E 00 1 D 4 Note Off
Loop Control - RIGHT DECK (ON/OFF Button)
00D6BDF6 3 -- 90 45 7F 1 A 4 Note On
00D6BE63 3 -- 90 45 00 1 A 4 Note Off
Loop Control - RIGHT DECK (1/2 X Button)
00D6F62D 3 -- 90 43 7F 1 G 4 Note On
00D6F69F 3 -- 90 43 00 1 G 4 Note Off
Loop Control - RIGHT DECK (2 X Button)
00D726E0 3 -- 90 44 7F 1 G# 4 Note On
00D72732 3 -- 90 44 00 1 G# 4 Note Off
Loop Control - RIGHT DECK (Shift Back Button)
00D76372 3 -- 90 46 7F 1 Bb 4 Note On
00D763CA 3 -- 90 46 00 1 Bb 4 Note Off
Loop Control - RIGHT DECK (Shift Forward Button)
00D79C61 3 -- 90 47 7F 1 B 4 Note On
00D79CAF 3 -- 90 47 00 1 B 4 Note Off
Manual Mode / Auto Loop Button RIGHT DECK
00E23CD5 3 -- 90 48 7F 1 C 5 Note On
00E23D18 3 -- 90 48 00 1 C 5 Note Off
In (Begin Loop) / 1 Beat AutoLoop Button - RIGHT DECK
00E27835 3 -- 90 49 7F 1 C# 5 Note On
00E27868 3 -- 90 49 00 1 C# 5 Note Off
Out (End Loop) / 2 Beat AutoLoop Button - RIGHT DECK
00E2B05D 3 -- 90 4A 7F 1 D 5 Note On
00E2B0B0 3 -- 90 4A 00 1 D 5 Note Off
Select / 4 Beat AutoLoop Button - RIGHT DECK
00E2E700 3 -- 90 4B 7F 1 Eb 5 Note On
00E2E749 3 -- 90 4B 00 1 Eb 5 Note Off
Reloop / 8 Beat AutoLoop Button - RIGHT DECK
00E3128B 3 -- 90 4C 7F 1 E 5 Note On
00E312D6 3 -- 90 4C 00 1 E 5 Note Off
TAP BPM Button - RIGHT DECK
00E3B943 3 -- 90 3F 7F 1 Eb 4 Note On
00E3B9B0 3 -- 90 3F 00 1 Eb 4 Note Off
Track BACK Button (Underneath Strip Search) - RIGHT DECK
00E3F46C 3 -- 90 40 7F 1 E 4 Note On
00E3F4B9 3 -- 90 40 00 1 E 4 Note Off
Track Forward Button (Underneath Strip Search) - RIGHT DECK
00E45C07 3 -- 90 41 7F 1 F 4 Note On
00E45C52 3 -- 90 41 00 1 F 4 Note Off
DELETE Cue Button - RIGHT DECK
00E49ED3 3 -- 90 33 7F 1 Eb 3 Note On
00E49F2E 3 -- 90 33 00 1 Eb 3 Note Off
Hot Cue 1 - RIGHT DECK
00E4D199 3 -- 90 34 7F 1 E 3 Note On
00E4D1F5 3 -- 90 34 00 1 E 3 Note Off
Hot Cue 2 - RIGHT DECK
00E52CC6 3 -- 90 35 7F 1 F 3 Note On
00E52D03 3 -- 90 35 00 1 F 3 Note Off
Hot Cue 3 - RIGHT DECK
00E559FF 3 -- 90 36 7F 1 F# 3 Note On
00E55A4E 3 -- 90 36 00 1 F# 3 Note Off
Hot Cue 4 - RIGHT DECK
00E585A8 3 -- 90 37 7F 1 G 3 Note On
00E585E0 3 -- 90 37 00 1 G 3 Note Off
Hot Cue 5 - RIGHT DECK
00E5CACD 3 -- 90 38 7F 1 G# 3 Note On
00E5CB09 3 -- 90 38 00 1 G# 3 Note Off
SYNC Button - RIGHT DECK
00E5FF9A 3 -- 90 30 7F 1 C 3 Note On
00E5FFF1 3 -- 90 30 00 1 C 3 Note Off
00E62D99 3 -- 90 31 7F 1 C# 3 Note On
00E62DE6 3 -- 90 31 00 1 C# 3 Note Off
Play/Pause Button - RIGHT DECK
00E65C8C 3 -- 90 32 7F 1 D 3 Note On
00E65CD7 3 -- 90 32 00 1 D 3 Note Off
Pitch RANGE Button - RIGHT DECK
00E6EF26 3 -- 90 3B 7F 1 B 3 Note On
00E6EF79 3 -- 90 3B 00 1 B 3 Note Off
Keylock Button - RIGHT DECK
00E73ABF 3 -- 90 3C 7F 1 C 4 Note On
00E73AF8 3 -- 90 3C 00 1 C 4 Note Off
PitchBend - (Minus) - RIGHT DECK
00E774A0 3 -- 90 39 7F 1 A 3 Note On
00E774D2 3 -- 90 39 00 1 A 3 Note Off
PitchBend + (Plus) - RIGHT DECK
00E7AE0B 3 -- 90 3A 7F 1 Bb 3 Note On
00E7AE3F 3 -- 90 3A 00 1 Bb 3 Note Off
Pitch Slider (From 0 to Negative 0) RIGHT DECK
Pitch Slider (From 0 to Positive 0) - RIGHT DECK
5%
