hi y'all
I've just upgraded from cue 5 to vdj pro 6
I cant seem to activate the karaoke plug in ie when I go to effects > video effects & highlight karaoke there is no activate button
any advice ?
cheers
B
any advice ?
cheers
B
geposted Wed 03 Jun 09 @ 4:47 pm
Same here.. no activate button.. I know it uses DECK 1 ... but playing on that didnt work either....
geposted Thu 04 Jun 09 @ 8:57 am
logged a ticket with tech support
they told me to reinstall the software
done that still the same )-:
geposted Thu 04 Jun 09 @ 4:11 pm
First delete the Karaoke.dll then re-install. It works fine here ..
geposted Thu 04 Jun 09 @ 6:31 pm
just tried that & it hasn't worked ..... any other suggestions ?
geposted Sat 06 Jun 09 @ 7:18 am
found the solution myself
install direct x from Microsoft and the karaoke plug in works
mods/ admin - I am available to assist for the right fee !!!!!
geposted Sat 06 Jun 09 @ 9:17 am
Well, since Karaoke is a plugin you could have looked in the plugin forum, where you would have found this thread:
https://virtualdj.com/forums/95136/Virtual_DJ_Plugins/Plugin_not_working__Controls_not_showing_______Read_this_before_posting_____.html
geposted Sat 06 Jun 09 @ 12:58 pm
